should i run aluminum harmornic balancer
Old Dec 5, 2012 | 08:19 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
I have an aluminum harmonic balancer and i want to run it on my freshly built 1st gen small block350. This car will be driven on weekends and it should perform well. Someone told me not to run the balancer on street car. Any thoughts?
Old Dec 6, 2012 | 10:59 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: should i run aluminum harmornic balancer
With the extent of the information you've provided, the answer is no, don't use it.
Even if that damper was custom built for a specific engine/use/rev range, a heavier steel damper probably will make more power and provide more protection to the crank.
Old Dec 7, 2012 | 10:30 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
thanks, i was told they are good for the strip. he told me with the water pump, power steering, etc... it may strip the pulley bolts and yank the pulley off the front of it.
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
InfinityShade
Aug 22, 2015 08:00 PM
cRoe4
Aug 7, 2015 08:46 PM
