Probably a stupid Question..
Old Dec 6, 2012 | 08:16 AM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
I happened to come across a 96 Corvette Eng and was wondering if i could put all my "L98" parts on it.. stock and aftermarket.. sensors.. etc..
Basically make it work w/ my ecm..?
Old Dec 6, 2012 | 09:50 AM
David 91RS/Z28's Avatar
Re: Probably a stupid Question..
Even if you could I don't think you would gain anything. The intake and head design is what makes the power on the GEN II engines.
Old Dec 6, 2012 | 11:07 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
With enough work, sure, however you'd be a LOT better off getting rid of your L98 junk, and installing the entire engine with the correct PCM, wiring, etc.
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
gta892000
Sep 16, 2015 12:37 AM
