....just about stumped
Old Dec 7, 2012 | 03:46 PM
tragic_hero87's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
first of all, whats up everybody? long time lurker of this forum but just recently actually bought a camaro.
here's what i got
so i pick up a 92 rs(305tbi/t5) a couple weeks ago, drives great runs fine. couple weeks go by and i have it running with the hood up. i hear this very light ticking. i get closer and i can see that some of the spark plug wires are arcing. change those out and car starts up and runs even better than it did before. drive it for the rest of the day. next morning start it up and the idle is really low and its stumbling like its gonna die then the idle shoots up to 1800-2000 rpm and the SES light comes on. then it steadily creeps back down to normal idle speed but now smells extremely rich with a little white smoke. paper clip'd the aldl and got codes 33(map sensor reading low vacuum) and 44(o2 reading lean).
question
tomorrow im going on the hunt for the vacuum leak but the white smoke and lean reading make me think misfire. distributor maybe?
any help would definitely be appreciated.
Old Dec 7, 2012 | 07:51 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: ....just about stumped
I would do a full tune up on the car. Every car i have ever bought the first thing i do is plugs,wires,cap,rotor,air&fuel filter, and i also go threw the brakes. It's also a good thing to check all the front end components. When i bought my 89 i drove it for a month with the centerlink to pitman arm nut loose as hell with a broken cotter pin.
It also wouldn't hurt to replace all the vacume lines.
Old Dec 7, 2012 | 09:17 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
I would check the vacuum line going to the MAP. That would cause a low vacuum reading for the MAP (maybe its disconnected or the vacuum line is broken)and also cause the lean code from the vacuum leak.
Old Dec 7, 2012 | 09:37 PM
Damon's Avatar
Agreed with above- full tune-up (cap, rotor, plugs, wires), check the vacuum line to the MAP sensor and lastly a fresh O2 sensor.
Beyond that you're going to have to get a scan tool to tell you what's going on. I could speculate about a bad coolant temp sensor (TPS) but you're really just guessing without seeing things the way the ECM sees them beyond a certain point.
Old Dec 8, 2012 | 12:49 PM
Car: 92 Camaro RS
Engine: 305 TBI
Couldnt hear the leak at first but traced all the lines and found it. It was the line going to the MAP. Thanx jermdm
Old Dec 8, 2012 | 07:31 PM
jermdm's Avatar
Car: 1989 Iroc-z
Glad you found it and glad I could help. Happy driving.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
djmarch
May 8, 2016 11:32 AM
Quzyle
Oct 15, 2015 03:35 PM
tuningnewb
Sep 23, 2015 07:06 PM
camarohelp
Sep 22, 2015 03:19 PM
