Fuel Pressure Regulator
Old Dec 19, 2012 | 01:23 AM
supertrade's Avatar
I need to replace the fuel pressure regulator on a 1990 Firebird Formula 305 V8.
Does anyone know where I can find a tutorial? I watched some youtube videos on replacing these for other makes/models..seems pretty straightforward. I cant seem to find the regulator on my engine. Where is it located?
Thanks!
Old Dec 22, 2012 | 05:56 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: Fuel Pressure Regulator
If it's a TPI, the regulator is under the rear of the intake in front of the distributor. You will have to remove the intake plenum to replace it. You'll see a vacuum line running into it.
Old Dec 22, 2012 | 09:14 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/tpi/...i-removal.html
Remove the lower runner-to-manifold bolts, using the T-40 socket. There are 6 per side.
**One bolt per side is hidden and only accessed from inside the manifold area.
The one for the passenger side is accessed near the thermostat housing area, and the one for the driver.s side is accessed between the fuel pressure regulator and the distributor.
Having a good selection of extensions makes removing that driver's side one easy
Red shows the location of the bolts referenced in the post above that come from opposite side of the runner being removed
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
