5.7 tpi hows best to check injector pulse
Old Dec 24, 2012 | 01:21 PM
gta power's Avatar
hi all 1989 trans am gta convertible not starting ive got power to all fuses relays ect can hear the fuel pump prime. got fuel to the rail. has had new distributor coil ignition module pick up coil. have had it running by spraying fuel down the throttle body but wont get any fuel on its own. i got to now check fuel pressure and injector pulse. i got power to the injectors with noid light but hows best to check the injector pulse can i check it with the noid light or can i make a light bulb with wires to go on the connector. abit of help would be usefull as not that amazing with engines thanks.
Old Dec 24, 2012 | 01:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 5.7 tpi hows best to check injector pulse
If the noid light is flashing, you have injector pulse.
Old Dec 24, 2012 | 02:16 PM
gta power's Avatar
so i dont need anything to the ground on the connector just the noid light on the power pin crank it over and see if its flashing
Old Dec 24, 2012 | 03:43 PM
BLACK92B4C's Avatar
Car: 92 B4C 1LE/2010 GT/2003 P71/2002 Z2
Engine: 5.7/4.6/4.6/5/7
Transmission: A4/A5/A4/A4
Axle/Gears: 3:23/3:73/3:23/3:73
right, noid light plugs in like a bulb. My kit has a fiber optic cable with a suction cup on the windshield to see it from the seat as you crank.
Old Dec 24, 2012 | 03:53 PM
gta power's Avatar
right ok boys thanks for the replys i will check it tomorrow. if no pulse and fuel pressure is ok what do you think it will lead to the ecm/ecu. it has vats but light is coming on with ignition and going out when cranking. by the way this test light is the single pen type not the test light with two pins that plug in the connector
jklein337
Sep 19, 2018 06:23 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
