Small Cap Swap; Wire Orientation Question
Car: 87 Callaway/90 Zr-1/92 ZR-1
Engine: TT TPI/LT-5
Transmission: 4+3/ZF-6
Axle/Gears: 2.73/3.45/4:09
I am converting to a small cap dist, are the position of the plug wires on the cap the same? The cap I have has a mark between the two plug ins.....hard to explain but wondering if wire for cyl#1 sits differently on a small cap....not sure if that makes sense...
Engine: TT TPI/LT-5
Re: Small Cap Swap; Wire Orientation Question
Is #1 where my index finger is or still where it is on an regualr dist(pinky pointing to it)?
Small cap, HEI cap, there's no difference.
From your picture, your little finger is pointing to the conventional #1 location (give or take).
Engine: TT TPI/LT-5
Thanks, when I saw the line on the cap, I thought maybe it was different....much appreciated!
1992 Trans Am
May 10, 2023 07:19 PM
