Wheel bearing recommendations?
Old Jan 7, 2013 | 01:06 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Pretty self explanatory. I know Timken makes good bearings, but I can't seem to find the matching inner/outer bearing part numbers for it (I see the LE option but I definitely don't have that so they're not usable). This is for my 88 RS. Price isn't an issue, I just want quality bearings that will live up to abuse. I also only need part numbers for the front; I've got a 9" on the way right now so the rear is already taken care of.
Old Jan 7, 2013 | 07:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Wheel bearing recommendations?
The SET6 inner bearing, SET34 outer. Any of the parts stores should carry them.
JamesC
Old Jan 7, 2013 | 07:18 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Are Timken's still U.S.A.
Old Jan 7, 2013 | 01:14 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
timken is still mostly made in the USA,i have found some from Canada,Australia,France and Poland also.
Old Jan 7, 2013 | 03:51 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
JamesC
ordering from RockAuto right now, that's why I'm asking. Haha . I'm finishing up the odds and ends on the car, and I'm in the process of ordering the remaining steering replacements. Figured I might as well replace the bearings while I'm at it since they're cheap in comparison and seem to be fairly easy to replace. Thanks for the heads up.
Old Jan 8, 2013 | 11:00 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Along the same lines, do you have to replace the rotors at the same time? Or is the race removable? Im wanting to do mine this winter as well. Thanks
Old Jan 8, 2013 | 11:03 AM
JamesC's Avatar
The race can be removed/installed. IIRC, I used a brass drift, whacking North, South, East, and West.
JamesC
Old Jan 8, 2013 | 11:38 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
I bought a set of Delco branded NDK bearings for my 72 GTO.
The inner set was stamped NDK made in USA
The outer set was stamped NDK made in china !!!!!!!!!!!!!
Old Jan 8, 2013 | 12:02 PM
Edwardgp's Avatar
Engine: 454-350
Them dang Chinese are every where.
Old Jan 8, 2013 | 02:42 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
timkin is in braintree mass you can send them a burnt bearing from another car they will match it up and send what you need I've been there several times when Ilived in mass they have every bearing imaginable.
Old Jan 8, 2013 | 04:23 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
These bearing sets are very common so they are cheap. Buy something brand name such as Timken, SKF or National. Don't forget new inner seals while you're at it.
Old Jan 8, 2013 | 04:57 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
^ What he said. I bet most of the brand name stuff are probably made at the same factory. I bought National ones from Auto parts store here. Also know if you're doing new rotors they usually come with races already installed. Don't forget your high temp grease and work out the air bubbles and pack the heck out of the bearings too. New cotter pins too. The old ones usually are bent to heck.
I found the races from the new bearings work great as a inner seal installer. Fit great to let me tap the seal in flush. I'm keeping mine around just to use them for that purpose.
Old Jan 8, 2013 | 09:24 PM
joshc's Avatar
Car: 1986 Trans Am
Unless your rotors are like new, I would replace them while everything is apart.
I see them on ebay for $35 each free shipping.
Not worth the trouble tearing it all apart twice if they are worn substantially now!
Old Jan 9, 2013 | 06:59 AM
3rdgenmaro's Avatar
Car: 88 IROC
I ordered all Timken parts yesterday from RockAuto. 2x sets of inner and outer bearings and the inner seals. $21 Hard to beat.
Old Jan 16, 2013 | 11:01 AM
3rdgenmaro's Avatar
Car: 88 IROC
Just an FYI, since it came up earlier..........Both sets of Timken Bearings are stamped "USA"
The Timken inner seal however is made in Taiwan.
Old Jan 17, 2013 | 11:36 AM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Mine just came in and are also stamped USA, for reference.
Old Jan 17, 2013 | 05:48 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Brand name parts typically have some minimum engineering standard that y ou can rely on. Just having the name "USA" printed on them isn't always enough. It's completely legit for the USA Manufacturing Company of China to print "USA" on the part.
Old Jan 26, 2013 | 10:30 PM
stickySC's Avatar
Car: 03 Gmc Sierra ,85 camaro, astro
Engine: 305,
Transmission: a4
the bearings in my 85 were plastic. I went to replace them. The front outers the national brand , only thing they had were .015 or .030" cant remember exactly. but different. the bearings were ok. so i returned the new ones. stuffed em with grease and their still rolling around. I just mentioned this since no one else has..
J-money
Jan 4, 2019 09:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
