Loud ticking
Old Jan 10, 2013 | 06:28 PM
Jhook's Avatar
Car: 1991 Z28 Camaro
Engine: 5.0
Loud ticking
Kind of looking for clarity here, over the last 2 days, a tick has been coming from my engine, 305 Lb9 TPI, and I guessed it came from the #7 cylinder cause you can clearly hear it from the inside. Its completely consistant with RPM, cant hear it when idling. When I unplug the #7 fuel injector, tick goes away...whats causing it?
Old Jan 10, 2013 | 06:47 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Loud ticking
pushrod motor
ticking sound comes on suddenly
stuck lifter?
Old Jan 10, 2013 | 06:53 PM
Jhook's Avatar
Engine: 5.0
Re: Loud ticking
Originally Posted by W.E.G.
pushrod motor
stuck lifter?
Motors been rebuilt but we reused the lifters, Im hoping its an easy fix, I dont want to take off the manifold again
Old Jan 10, 2013 | 07:15 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Loud ticking
might only be a blown exhaust gasket-that would stop ticking when injector unplugged
Old Jan 10, 2013 | 07:29 PM
Jhook's Avatar
Engine: 5.0
Re: Loud ticking
How could I determine a bad gasket? I just took the valve cover off and the push rods are fine, and there isnt any excessive play in the rocker arms.
Old Jan 10, 2013 | 07:31 PM
W.E.G.'s Avatar
Engine: V6 2.8
Re: Loud ticking
AUTOMOTIVE STETHOSCOPE is cheap to come by, and can help you listen to specific components during troubleshooting
Old Jan 10, 2013 | 07:37 PM
W.E.G.'s Avatar
Engine: V6 2.8
Re: Loud ticking
I think you will need to turn the motor over slowly one revolution, and observe the rocker arms for excess clearance at various intervals to conclude that there are no lifter problems. This test can be further skewed by the fact that a "stuck lifter" can be stuck intermittently, and fine at other times.
You should do this test when the motor is fully warmed, and only recently turned-off. Otherwise the lifter could be stuck from just being cold, and the pressure inside the lifter could bleed down if the car has been sitting for any length of time.
Old Jan 10, 2013 | 07:53 PM
Jhook's Avatar
Engine: 5.0
Re: Loud ticking
gave it a few revolutins by hand, seems good. I just hope cams not getting chewed up
Old Jan 10, 2013 | 08:10 PM
W.E.G.'s Avatar
Engine: V6 2.8
Re: Loud ticking
OK
We'll say the lifter is good.
Cylinder knocks when fuel is provided.
Weak spark and/or fouled valve causes detonation?
Does the plug in the offending cylinder have sooty deposit?
Bad plug wire causing weak spark?
Old Jan 10, 2013 | 09:42 PM
Jhook's Avatar
Engine: 5.0
Re: Loud ticking
OK
Pulled spark plug, looks good. wires arent leaking spark...looks like a trip to the shop is in order...
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
