tell me my engine is not junk
Old Jan 11, 2013 | 12:07 PM
monsterjam5000's Avatar
i did a compression test today, each cylinder was +/- 150 on my gauge. i did not do cylinder 7 i could not get the gauge in there, will try againg later.
cylinders 1-6 around 150 all close to each other maybe 1-2 pounds different.
my problem is cylinder 8 has 0 psi on the compression test gauge, what could this be?
how could i test it more?
is it the cylinder or the head?
maybe rockers to tight and keeping valves from sealing?
thank you for your help
Old Jan 11, 2013 | 12:13 PM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
Re: tell me my engine is not junk
Hook up an air compressor to the cylinder and listen for air leaking in either of 3 locations. Exhaust, Intake, and oil fill. Also remove the valve cover and look at the valvetrain. Pretty easy to determine where the problem is.
Old Jan 11, 2013 | 12:38 PM
gp90gta's Avatar
Car: 1990 GTA
Yup agreed, what he means about the valvetrain in to just make sure the cam is on the base and both valves are closed before you test.
Old Jan 11, 2013 | 01:10 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
your engine is not junk just because you told me to tell you that but it does sound bad
Old Jan 11, 2013 | 01:21 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Zero pressure suggests valve not fully closed.
Most likely an exhaust valve.
Old car needing valve work does not make the engine junk by a long shot.
Just means its going to pick your pocket. But, its an old car, and you knew that already.
Old Jan 12, 2013 | 12:34 AM
I just fixed a push rod and lifter on that cylinder. So I'm hoping I put something together wrong I'm going to check it here in a minute. I will let you know
Old Jan 12, 2013 | 06:10 AM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
Oh , colapsed lifter may be you should have used a used one . if its tapping it may fill itself up after running a few min . wait that doesn't sound rite....... you may have not adjusted the rocker properly. yea that sounds better ,but why did you change the lifter in the first place ?
Old Jan 12, 2013 | 06:54 AM
Anti-Venom's Avatar
Axle/Gears: BW 3.23
Old Jan 12, 2013 | 08:48 AM
Sounds like you tightened that rocker WAY too tight, and the valve is getting held open.
It's amazing sometimes, how helpful a little "history" can be, to zeroing in on problems. First thing to do is, ALWAYS go back and check your work.
Old Jan 12, 2013 | 04:58 PM
Rockers to tight
TheJoeY88
Dec 31, 2016 07:30 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
