vortec 305tpi with lt4 hot cam???
Old Jan 13, 2013 | 02:08 PM
macneilbibi's Avatar
Car: 1988 Pontiac Firebird Formula WS6
Axle/Gears: Borg Warner 9 bolt 3.45 gear
i have been thinking about redoing the top end of my motor for some time, my engine does smoke on start up and when it gets to 220 degrees. but not all the time, some days are better than others lol
videos of car running
The Engine: LB9 305ci (5.0L) with 220hp and 290tq
numbers from when i dyno'ed the car in 2010
numbers of dyno test
video on dyno
now for what i want to do to it
http://www.summitracing.com/parts/nal-12558060 x2
http://www.summitracing.com/parts/nal-12480002
http://www.summitracing.com/parts/fem-205-6285m000
http://www.summitracing.com/parts/hok-2055hkr
http://www.summitracing.com/parts/sl...model/firebird
which would be a 305 tpi with stock bottom end with vortec heads and lt4 hot cam
CAN THIS BE DONE???? what problems will i run into??
i need major help on this
anything would help
i plan on doing something this summer
Thanks... macneilbibi
Old Jan 13, 2013 | 11:56 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: vortec 305tpi with lt4 hot cam???
IMHO, you're going to lose too much compression with those heads and an LT4 hot cam is a lotta' cam for a 305. There's nothing wrong with modding a healthy 305. But, if it needs to come out and be rebuilt, there's no good reason not to go 350. Same money, more power. If you're hell bent on a 305, a set of 113 heads is a better choice along with an LT1 cam or equivalent.
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
