350 GM Goodwrench Power Adding
Old Jan 18, 2013 | 02:23 PM
muggymatt88's Avatar
Car: 89 Camaro Iroc
I have an 89 Camaro with a 350 Gm Goodwrench with a Edelbrock carb with hooker headers 3 inch exhaust to flowmaster mufflers. But every thing else stock . What can i add to increase Hp for the Best Bang for my Buck?
Old Jan 18, 2013 | 05:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 350 GM Goodwrench Power Adding
How big is your buck?
Read
http://www.chevyhiperformance.com/te...d/viewall.html
http://www.chevyhiperformance.com/te...i/viewall.html
http://www.chevyhiperformance.com/te...ine_build_iii/
http://www.chevyhiperformance.com/te...gine_build_iv/
http://www.chevyhiperformance.com/te...ngine_build_v/
http://www.chevyhiperformance.com/te...gine_build_vi/
Old Jan 18, 2013 | 06:48 PM
Car: 89 Camaro Iroc
I'm willing to spend up to $1000
Old Jan 19, 2013 | 02:52 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Set of vortec heads, intake, and a mild flat tappet cam are a great way to get some more bang for your buck, all of which can be had for around 1k new. The stock smogger type heads are the biggest restriction in the engine, and have lousy compression, somewhere around 8.2:1 by my calculations. Vortecs will get you up to around 9:1 and a lot more flow.
Old Jan 19, 2013 | 02:56 AM
Car: 88 Camaro SC
Engine: SFI'd 350
On my goodwrech I have the TFS super 23 195's with an XE270 roller (similar to that covered in part VI), and that setup works quite nicely, but is expensive. The older vortec heads and modest Isky cam worked quite well with good low end torque when I had them with my old TBI setup. If you go the vortec route, the stock springs can be used with a mild cam, but its good to check the max lift. Mine bottomed out on the seals at .460".
Old Jan 19, 2013 | 01:28 PM
joshc's Avatar
Car: 1986 Trans Am
I'm planning on getting a goodwrench 350 for my firebird in the spring.
There is a GM dealer selling on ebay for $1425 with free shipping. I can't rebuild my 350 any cheaper, and remaned short blocks are going for almost that much money.
My plan is to swap in a bigger cam before I install it in the car. A year or 2 down the road as my budget allows, I plan on swapping on some better heads with smaller chambers to bump up compression.
You can get these complete aluminum heads off ebay pretty cheap!
http://www.ebay.com/itm/New-Flo-Tek-...341920&vxp=mtr
OR
You can get the cast iron Vortecs for about $300 each that would also work great.
Old Jan 19, 2013 | 03:21 PM
Damon's Avatar
Or you could just buy a Vortec long block that comes with the heads and has a factory roller cam (not a big one- just the regular pickup truck cam). Last time I checked Summit had them for about $1900. Would make a roller cam upgrade much less expensive later since you already have all the roller gear (no pricey aftermarket conversion required).
Old Jan 19, 2013 | 09:14 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
If your car runs nice, I would look at mods to support what you have and get you ready for future mods. Your profile says you have 2.73s, I would go with 3.73s and a 2500 converter. That's a big bang for the buck.
Old Jan 20, 2013 | 12:34 AM
Car: 88 Camaro SC
Engine: SFI'd 350
As far as the goodwrench goes, if you only plan on running a cam that can use stock springs, then its a good deal. The flat tappet with softer springs will be just as reliable as a roller. If your wanting to stab something big in it, though, then getting a roller block up front is a much better deal. Flat tappets with heavy springs equals wiped lopes after a while with street driving.
Old Jan 20, 2013 | 07:05 PM
rs89todd's Avatar
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
agreed with unknown, maybe some subframe connectors, but i recommend the 3.73s then stall or sfc
Old Apr 1, 2013 | 08:12 PM
Car: 89 Camaro Iroc
Would i be able to supercharge to this engine with out full blown modification like new pistons. I dont want to run a large supercharger just something for like 50 to 75 hp. Im new to power adders like superchargers and turbo's.
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
