Clanking sound from engine
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
So just today I bought an 84 camaro because my firebird caught on fire.
I took the air cleaner off to look at it, then put it back on. When I went to drive away and put my foot down, the linkage jammed.
I got on the clutch and the motor revve'd up waaaay too much extremely fast.
I shut it off as quick as I could, but now it is making a serious clanking noise. It doesnt sound like a rod knock, alot more serious then just valve tick, and it still runs. I cant tell exactly where from, what should I look for?
Re: Clanking sound from engine
It don't sound good for the home team.
Broken crank, broken rod, etc. Can't be good.
Best not to run it any more until you find the source; the more you run it the more stuff it'll tear up.
Car: White 84 z28
Engine: Chevy 350
How do I begin doing that? Would the only way be to tear apart the whole engine?
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Pull motor. Pull pan and valve covers. Inspect clutch. Pull valve covers before yanking out and check rockers and pushrods.
