compression test numbers too high?
Old Jan 28, 2013 | 03:46 PM
camarito's Avatar
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
i took out my headers to replace and decided to change the spark plugs while i was at it did some compression tests and all cylinders were above 200psi with #8 and 2 over 210psi i even tested the gauge against 2 other gauges and they all match perfect, i used 5 strokes in all of them.
The engine was my first built, it has about 15k miles and feels very powerfull but i wasn't expecting readings that high.
Is it normal?
Old Jan 28, 2013 | 06:10 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: compression test numbers too high?
Is it normal?
I'd be happy with that!
Just keep running good gas in it and enjoy it
Old Jan 28, 2013 | 06:21 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Those aren't bad.. Those numbers are pretty even. Low compression numbers are what I would be concerned with
Old Jan 29, 2013 | 01:03 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
It is hard to do a good compression test on a Hyd roller cam. The higher valve spring pressures cause the lifters to blead down and give false high numbers and false cylinder to cylinder differences. You probably are seeing inflated numbers.
Old Jan 29, 2013 | 06:07 PM
camarito's Avatar
it's not a roller cam but i'm using roller cam rated springs, don't everybody test them the same way? i looked all over the internet and couldn't find a different way, the motor was verry tight when i build it, hard to turn with the breaker bar and i did folow KB ring gaps recomendations.
I dit talk to a friend mechanic/engine buider and he said it was not comun but he've seen that before, what he was surprized is it runs good on 87 octane at 32*
Old Jan 31, 2013 | 08:30 PM
Damon's Avatar
Sounds about right for an engine with mid-low 10s compression and a smallish cam.
Chances are the aluminum heads are helping you out a little bit with the cheap gas. That will change over time as carbon builds up on the chambers, valves and piston faces. And 32* is already a couple degrees shy of what you want for maximum power with typical non-Vortec heads (somewhere around 36* is usually the sweet spot).
But remember that every engine wants something a bit different. Yours just happens to be OK running like that. It could be a different story on another engine, even if it's built similarly. I suspect you are near the limit, though. Step up any more with spark advance or compression it would probably go over the line.
Old Jan 31, 2013 | 08:53 PM
skinny z's Avatar
Is it normal?
200 psi is an excellent cranking pressure. Test parameters like ambient temp, engine temp, atmospheric pressure of the day all play a part in how a cranking test will play out though. You also have the consider the intended purpose of the engine. A target of 180 for a street build is a minimum where a dedicated drag racing engine would be beyond 220-240 psi (NA, gasoline)
What are your engine specs? Cam timing, (w/installed postion), engine dimensions, pistons, etc and so forth? (If you care to share).
Azrael91966669
25
Jun 20, 2017 04:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
TA8487
Aug 16, 2015 12:21 PM
BBSDesigns
Aug 11, 2015 07:39 PM
