What kind of valve covers are you gusy using on centerbolt heads?
Old Feb 10, 2013 | 10:50 AM
Blue1990camaro's Avatar
hey guys, just curious how you guys have dressed up your 86+ sbcs, iv never had a motor with center bolt heads so im not sure what to do about valve covers? was curious what corvettes look like or if they are even find able? stock vs chrome? post pics of what you guys have done with your center bolt valve covers
Old Feb 10, 2013 | 11:08 AM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
Re: What kind of valve covers are you gusy using on centerbolt heads?
I got these on ebay but they are cheap junk. I was tightening the driver's side down and I only snug them enough so the gasket will seal. I heard a pop and found I had cracked it from the oil hole forward through two bolt holes. I put JB Weld on it but I doubt if it will hold.
Old Feb 10, 2013 | 11:12 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
heres mine :
Old Feb 11, 2013 | 08:04 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
stock covers.
Old Feb 18, 2013 | 12:39 AM
midnight89 those are extremely cool looking, very old school looking, hate to hear that they cracked easy on you, what are they made of? cast aluminum?
Old Feb 18, 2013 | 01:18 AM
Copperhead's Avatar
Can't remember the brand
Attached Thumbnails What kind of valve covers are you gusy using on centerbolt heads?-383.jpg
Old Feb 18, 2013 | 01:25 AM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
Yeah, cast aluminum and apparently, not very much of it. They have no strengthening ribs on the underside and I did not have it very tight when it cracked.
Those are Proform covers and were my second choice, I wish now I had went with them. I'm considering some smooth polished aluminum ones if I can find a place to engrave something into them.
Old Feb 18, 2013 | 09:51 PM
that would be awsome ^
i was looking on summit and i found a set of those in chome, i also found a set that look like our stock ones but chrome with a red bowtie and stripes, im thinking about getting them, they are around $110
Old Feb 18, 2013 | 10:57 PM
Westech's Avatar
Car: 1991 Camaro RS
Axle/Gears: 7.6" 3.73 yukon locker
I run stock GM valve covers... there tough look factory and cheap... just got a new set with gaskets and blots all Gm for 40 bucks
Old Feb 21, 2013 | 05:52 PM
ghost91's Avatar
Car: 1991 Camaro Z28
Not to impose on this thread..but you guys have any cleaning tricks on getting the baked on, stained oil off the valve covers? Its so unappealing, and im just wondering if i should just spend the money for some new ones like you guys mentioned above. Ive tried simple green, all three types of engine degreaser from GUNK. Any help would be greatly appreciated. Thanks
Old Feb 21, 2013 | 05:57 PM
Twin_Turbo's Avatar
fabricated
Old Feb 21, 2013 | 07:48 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Corvette magnesium valve covers with internal drip tabs.
Old Feb 21, 2013 | 07:59 PM
85 ZXX's Avatar
Please describe your valve covers..painted, chrome, aluminum?
Old Feb 21, 2013 | 08:23 PM
ghost91's Avatar
The regular stock ones.
Old Feb 21, 2013 | 10:24 PM
85 ZXX's Avatar
Go to this link below. This is what I used on mine. It works great!!!
http://www.ecklerscorvette.com/corve...1984-1991.html
Old Feb 22, 2013 | 03:32 PM
ghost91's Avatar
That was plan b if i couldnt find a way to clean them haha. Still searching for a way to clean them though. Thanks for the link too
Old Feb 22, 2013 | 07:19 PM
if you have chrome ones, a great way iv found to clean them is to use that soap soaked brillo pads (steel wool) you can buy for cleaning dish soap, they remove anything including rust off of older chrome anything
BUT i would NOT use it on any new chrome it may scratch it,
Old Feb 22, 2013 | 08:02 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
On anything except chrome or polished aluminum I suggest glass bead blasting at a low pressure.
Old Feb 22, 2013 | 08:18 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
went from polished alum.
To LT4 composit.
Old Feb 23, 2013 | 12:47 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I like the LT4 composite covers a lot. That looks great!
I also like the fabricated covers.
But when I got mine I ended up with cast covers. I dont like the look of stamped covers at all, but the die cast ones look great to me. I would be just as happy with the fabricated or composite covers, though. Not a huge fan of the vette covers. But I think the vast majority of non stamped centerbolt covers look WAAAAY better than perimeter bolt covers. And it's so nice to just RTV some nice rubber gaskets to the bottom of teh valve cover so tehy will stay in place, and then you never have to worry about valve cover gaskets again no matter how many times you pull the VC's off.
I need to clean mine up a bit, though.
Old Feb 23, 2013 | 01:18 AM
Twin_Turbo's Avatar
The composite LT4 covers are very nice, but they tend to be pretty expensive
Old Feb 23, 2013 | 07:31 AM
skinny z's Avatar
I've run the Proform model (as has been posted) but I'm having real trouble trying to get them to be leak free.
I've snapped off one the Proform bolts trying to get that last bit of pressure onto the sealing surface however it had bottomed out in the head. I've purchased better bolts and am running the double thickness cork/steel gaskets but still have a leakage issue.
Last edited by skinny z; Feb 23, 2013 at 08:34 AM. Reason: Because grammar and spelling count for something.
Old Feb 23, 2013 | 08:31 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Thanks. I got lucky and traded my polished aluminum ones for the lt4 ones. and picked up the fuel rail covers with them also. Im in the middle of filling the corvette logo on the covers and smoothing them out.
Old Feb 24, 2013 | 05:17 PM
85 ZXX's Avatar
You will really like this spray paint if you get it, it is a nickel lacquer which sprays like a paint gun. You can't tell that mine were painted. I have enough left over to give my original alternator case a fresh look.
Old Feb 24, 2013 | 05:46 PM
ghost91's Avatar
I'll have to pick some up and I'll let you know once the wethers nice how they come out. You take them off or just a lot of covering and taping?
Old Feb 24, 2013 | 08:41 PM
85 ZXX's Avatar
I took them off, cleaned them, wiped them lightly with a tack rag and painted.
Old Feb 24, 2013 | 09:07 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I want to say they were aluminum moroso valve covers... rather heavy but very sturdy. Easy to polish to keep clean too. With a little trimming they fit wide 1.5 roller rockers.
Old Feb 25, 2013 | 12:48 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
"Real" LT-4's:
Attached Thumbnails What kind of valve covers are you gusy using on centerbolt heads?-dscf2137.jpg   What kind of valve covers are you gusy using on centerbolt heads?-dscf2141.jpg   What kind of valve covers are you gusy using on centerbolt heads?-dscf2491.jpg
Old Feb 26, 2013 | 07:43 PM
wow i like those lt4s, and those other ones shown that arent stamped, to bad i only have an LB9, or would lt4s fit???
Old Feb 26, 2013 | 07:56 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
If they are center bolt heads they will fit. If not you can buy adapters to make em fit.
"REAL " Lt4s will clear roller rockerse xpect to pay $300+ish for a pair.
http://www.ebay.com/itm/LT4-LT1-Comp...4623f6&vxp=mtr
Old Feb 26, 2013 | 08:15 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
i had the same thing happen on my proform alum ones. its such a shame since they look so nice. heres the link to summit on the ones i had. the alum covers need a LIGHT touch when snugging down. almost so light to make you think they wont seal.
Old Feb 27, 2013 | 05:31 PM
85 ZXX's Avatar
Wow! There are some really nice pics of engines on this thread.
Old Feb 28, 2013 | 08:40 PM
yea i have center bolts, its n 85 iroc z tpi but the motor im about to put in was from an 87 iroc z tpi
Old Mar 3, 2013 | 02:32 AM
watajob's Avatar
Car: 92 T/A 'vert
True, no clearenceing involved. They bolted right over my Scorpions. But, yeah, real spendy.
Old Mar 3, 2013 | 11:53 AM
travis401's Avatar
Car: 91 Camaro RS
cork gaskets leak, theyre next to impossible to get to seal. switch to a rubber gasket and dont look back.
Old Mar 3, 2013 | 12:09 PM
skinny z's Avatar
Are you running the Proforms? I agree with you completely on your choice of gaskets.
With the OEM valve covers the blue silicone/rubber gaskets sealed up 100%. Tens of thousands of miles and everything stayed bone dry.
The first go round with the Proform covers was with the supplied bolts and the same style gasket.
They leaked.
I made a switch to the double thick cork hoping I'd be able to get a little more pressure applied before the bolts bottomed out.
No such luck. They leaked too.
I have to investigate the amount of contact the rockers are making with the baffles. With the Pro Magnum 1.6 rr I'm sure there is some. My thinking is that there is always a little movement with respect to the covers and they never fully seat themselves. I'll have to experiement with the upgraded bolts and various gaskets to come up with a leak proof seal.
I don't like leaks.
Old Mar 3, 2013 | 10:26 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Originally Posted by Twin_Turbo
fabricated
Man those valve covers look great did you do them I would like to have a set like them
Old Mar 4, 2013 | 06:01 PM
Twin_Turbo's Avatar
ebay cheapos
Old Mar 4, 2013 | 06:25 PM
Engine: LQ4 ls 6.0
ebay cheapos
Thanks for the info
Old Mar 4, 2013 | 09:05 PM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
I came real close to buying the black Proforms but now that I read your post and the others concerning leaking I am real glad I didn't. I'm working on a new idea now so if this thread is still alive when I get them on I will post pics.
Old Mar 6, 2013 | 02:53 AM
Car: 1992 Camaro RS
They leaked.
I don't like leaks.
Not sure which ones are the "Proform", but I've got pretty generic polished aluminum valvecovers. The machine shop I did all my business with threw em in for me when I was getting my setup together so I have no idea what brand they are, expected them to be something on the cheaper end and if I recall proform made some identical to mine. They're pretty generic really, but thats what I wanted. Regardless, I figure they are made by whoever makes the proform stuff and mine seal great and Ive got Comp Pro magnums also. I love the black proform covers...
https://www.thirdgen.org/forums/post...00-post20.html
My valve cover bolts and bosses are a bit different than the proform ones, though. They are countersunk in with allen heads... so maybe not Proform?
Old Mar 7, 2013 | 08:29 AM
  #42
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
Here's a pic of my "new" valve covers. Ignore the mistakes they are off again & being stripped to be painted again. This pic is to just give an idea of what I am doing, at least these are sturdy.
Old Apr 7, 2013 | 08:35 PM
  #43
id like to see more pics of your car Midnight85 that motor is gorgeous!
btw will that intake work on a tpi motor without moding much?
Old Apr 7, 2013 | 09:09 PM
  #44
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Not finished but here are my valve covers.
Old Apr 7, 2013 | 09:17 PM
  #45
wow i really like yours to jas370
Old Apr 7, 2013 | 09:42 PM
  #46
jas2730's Avatar
Thanks!
Old Apr 7, 2013 | 10:37 PM
  #47
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
Thanks, I'm glad you like it.
I'll probably get lynched for posting pics of a Corvette on a Camaro/Firebird forum.
The Pro Flo is a bit too much for a stock L98, it could probably be made to work but the throttle body is an LS style which are considerably larger than the 48mm. Mine is an 80mm. Also my engine is a 383 so it needs the extra air. As far as the install goes, the Pro Flo is sooo much easier to install than the tpi. If you need any more info, just ask.
Old Apr 10, 2013 | 11:06 PM
  #48
yea im not sure what i wana do yet, its just an LB9 with a cam and headers
Old Apr 11, 2013 | 01:08 PM
  #49
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Tall polished Ball milled,
Old Apr 12, 2013 | 04:38 PM
  #50
skinny z's Avatar
Those look like the Proforms I'm using. Which gaskets are you using and do you have any leaks?
