Setting Idle Stop Scew on TPI
Old Feb 10, 2013 | 06:37 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Car has 58mm Holley Throttle Body. How do you set the idle stop screw and and at the same time adjust the TPS voltage?
Old Feb 10, 2013 | 06:58 PM
camarorookie's Avatar
Re: Setting Idle Stop Scew on TPI
Adjust TPS first, then set minimum idle and go back and check TPS again. If it was way off you might have to do it more than once.
Old Feb 10, 2013 | 07:28 PM
MrPackstin's Avatar
Car: 1989 GTA
The problem then is the butterflies on the throttle body are more or less open than they should be at start-up. Am I missing something?
Old Feb 10, 2013 | 10:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by camarorookie
Adjust TPS first, then set minimum idle and go back and check TPS again. .
You disable the IAC , set min idle speed with the screw , then reset TPS
http://www.corvetteactioncenter.com/...-corvette.html
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
