L98 head swap help
Car: 1991 Camaro RS
Engine: 305 Small Block
Axle/Gears: Factory
L98 head swap help
have a l98 block out of a early 90s box van. I bought a intake/fuel injection set up off a 87 corvette, what heads will work and run will with that intake
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: L98 head swap help
A van 350 is an LO5, not an L98. You can use the swirl-port heads, you'll get maybe 220 HP and it'll peak at 4000 RPM. If you want more, you need to find some pre-Vortec 300-HP 350 crate engine heads. 64cc, 1.94 / 1.50" valves, and centerbolt valve covers, but NOT swirl-port. I forgot the casting number. They are rare, even though a few made it into marine use. Neither is a good solution, but both should be cheap and easy. I'd run '081 heads from an LB9, but you may need higher octane if you keep the LO5 cam.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Cute, but even legit L98s never had that RPO code anywhere on the block. Not cast in, not stamped in. L98 was for the paperwork. However, good luck differentiating a truck block from a Corvette block from a Trans Am block from a police caprice block except by the suffix code stamped on the RF deck above / behind the water pump pad. If you found L98 stamped, it wasn't GM who did the stamping. Never wise to argue with true experts just trying to win your argument. The best way for you to save face is to admit when you stand corrected.
Car: 1991 Camaro RS
Axle/Gears: Factory
I listen here *******, it's a ****in l98. Don't try and correct me again.
Car: 1991 Camaro RS
Axle/Gears: Factory
I know what I got. None of you have answered my god damn question, just dwelled on stupid ****, I know for a fact it's an l98 so all y'all need to shut the **** up and tell me what heads will work with that intake
Car: 1988 firebird formula 350
Axle/Gears: 2.77
Originally Posted by Camman9167
I know what I got. None of you have answered my *** question, just dwelled on stupid ****, I know for a fact it's an l98 so all y'all need to shut the **** up and tell me what heads will work with that intake
Posted from Thirdgen.org App for Android
Axle/Gears: 2.77
The first thing you should buy to make that intake work is 65# /hr injectors. Once you get those installed come back and ask for cam advice
Car: 1983 G20 Chevy
Transmission: 4L60
I put a production GM LT4 camshaft, 1.6:1 full roller rockers, edelbrock 3704 intake, 1" open center spacer, ultimate TBI moded TBI, doug thorley tri-ys, and tuned my own prom chip. The result was 255 RWHP/308 RWTQ, using STOCK swirl ports. This was with a massive mechanical engine fan, 2 piece driveshaft with carrier bearing, and a 9.5" 14 bolt corporate rear-end.
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
L98 only came in corvette and had aluminum pistons in some occasion and aluminum heads in some occasion from factory you have many replies about other members that know a thing or two about l98 im prety sure they are right unless you can prove it and have facts
Car: 89 Firebird
Engine: 355 TBI
L98 came in vettes camaros and firebirds. Mid to late year 86 vettes got aluminum heads on L98. in 87 L98s started in the f-bodies but had the iron heads.
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Quoting the great George Carlin: “Never argue with an idiot. They will only bring you down to their level and beat you with experience.”
Just saying.
Just saying.
Car: 89 Firebird
Engine: 355 TBI
Wonder if that L98 van had TPI being it was certainly an L98 stamped and all.
Car: 1983 G20 Chevy
Transmission: 4L60
With ported 906 heads, a ported edelbrock 3817 base, production LT4 cam, 1.6:1 roller rockers and Doug Thorley Tri-Y headers into a dual 2.5" exhaust setup it was fun to show GT Mustangs, 5.3 trucks and those 6.0 Escalades and ML550 mercedes SUVs what an old G-van tailights looked like.
Hello, Michael
Aug 20, 2015 03:19 PM
