Swapping out a cam...?How much it run?
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Alright so I got my lil LG4 engine mods so far are my Hooker 2055 headers, 3" straight pipes, edelbrock manifold. They've helped it out but still im getting small hondas beat me its pretty aggravating so Im thinking about taking my car to a shop to do my cam swap...whats something you guys recommend....Keep in mind it's my daily driver also like how much does it usually run?
I got a mechanic Hopefully hes gonna do my clutch this weekend for $250 in labor plus whatever parts I want...Just wanna know a rough estimate so I dont get ripped off...
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Swapping out a cam...?How much it run?
$250 is dirt as hell cheap for swapping a clutch.. Generally speaking, the average rate around here if someone "you know does good work" did it for you would be $750-900.
Swapping your cam without cylinder head work is asking to get your *** kicked even further. Don't even bother doing a cam swap until you address your cylinder head issue first.. or in your case (saying it before everyone else does) ditch that 305 you have for more displacement.
Car: 1984 Z28
hmm...I see....whats something else that i can do to get my car to actually wake up..Like I was thinking of getting it dyno tuned but they want $500-$600 to do it ova here
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
If your going to do a clutch and a cam at the same time, it's less work to take the motor out. Plus you can easily reseal it with new gaskets while it's out.
Changing cam in car pays 7 hours by the book.
Car: 1984 Z28
alright well isnt a clutch job around 6 hours if so...my guys chargin me $250 which equivilates too $41/hour....accorindg to this a cam swap would run $287...?any takers>?
Car: 1984 Z28
well ima prov go tomorrow and talk with the guy again to see if this is true.
Car: 1994 Z28
Engine: 355 LT1
Car: 1991 GTA
Engine: LB9
I'd be leery of a guy that will do a clutch for that little, as well as potentially doing the cam for that.
Unless of course, he is doing this out of his garage as side work. But even then...
Keep in mind third gens are a relatively heavy car. Are you getting beat by built Hondas, or posers with nothing more than a fart can? I hate to say it, but you are really going to have to step it up if you want to beat the properly built Hondas.
Car: 1986 Chevrolet Camaro Z28
Engine: 350 V8 4bbl
Transmission: Automatic 700r4
Axle/Gears: 2.73 Open Diff
If you're wanting power, you're gunna need to spend some money. The old saying of "There's no replacement for displacement" is pretty true, swap out to a 350 and start building from there. Get some 64cc heads, bigger cam, and if you really want to make power get a longer stroke crank and upgrade to flat top pistons. Also work on your gearing. Swapping to a Ford 9" rear end is a good start and with the posi unit you'll get better traction off the line too. It wont be cheap at all, especially if you're paying someone to install everything, but you will see a big difference in your cars performance.
P.s. Im only 16 and I already did all of this to my car. if you try pulling the im too young excuse that wont fly.
Fast355
Dec 2, 2016 06:33 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
