1987 350 vacuum help needed
Old Mar 6, 2013 | 07:40 PM
87tunedport's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0
ok i need some help. my throttle body has 3 exposed nipples that vacuum lines for my emissions used to be. the engine has been molested and lines were removed some were just plugged i have 2 on passenger side, and one on the bottom of the driver side. i have my emissions sticker on the hood it says ZDU but not as descriptive. any help is appreciated
Old Mar 6, 2013 | 07:47 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1987 350 vacuum help needed
vaclinesformyiroc.jpg?t=1325217059
The ones under the idle air housing are for coolant your better off leaving it the way it is.
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Top goes to pass valvecover.
2nd down goes to evap charcoal canister
3rd is coolant outlet. the inlet is in front under the t-body. its common to bypass this and its ok to leave open.
Edit: beat me to it ! lol
Old Mar 6, 2013 | 07:50 PM
Engine: Lb9
Transmission: M20
With a picture even lol
Old Mar 6, 2013 | 08:44 PM
TTOP350's Avatar
NEWMAN!!!
Old Mar 6, 2013 | 09:56 PM
Engine: Lb9
Transmission: M20
Old Mar 7, 2013 | 07:51 AM
Engine: 5.0
if the 3rd is for coolant wont the part be overheating? what does it cool? i never heard of the throttle body needing coolant but this is my first tuned port 350 firebird
Old Mar 7, 2013 | 08:01 AM
TTOP350's Avatar
Its to keep the throttle from freezing open or closed in cold weather driving.
Other than that it just adds unneeded heat to the incoming air.
If you drive in cold snowy weather, hook it up, if not, its fine as is.
Old Mar 7, 2013 | 01:06 PM
Engine: 5.0
no ill only be driving it in the summer months but right now im working on it therefore running it at times in my garage is that hurting anything? i looked on valve cover and saw PO put a breather on thats why the throttle body line was plugged, should i put it back or leave it like it is? is there anything to gain or loose?
theshackle
Sep 17, 2020 08:26 AM
IROCZ1989
Jan 24, 2016 03:55 PM
beachrodder
Aug 25, 2015 08:05 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
