Learning cams from the Ford camp
Old Mar 9, 2013 | 09:14 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
http://www.mustang50magazine.com/sho...g/viewall.html
Old Mar 10, 2013 | 08:48 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Learning cams from the Ford camp
The 12th paragraph isn't totally correct. The wide lobe separation angle by itself isn't hurting the upper-RPM power. It can correctly be argued that the lack of overlap hurts headers' tendency to extend the useful RPM range, but the problem is the lack of exhaust duration, or rather, the poor exhaust port flow for the better fix, and the long-runner intake manifold. The wide LSA delays the intake closing, and that alone extends the RPM range, even with a short-duration cam. The L69 was the first evidence, then the '90s LT1. Those 2 cams had less overlap than this, and less duration. But the lack of duration was what limited their top-end.
Old Mar 12, 2013 | 04:12 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
And from the Mopar camp: http://www.moparmusclemagazine.com/t...t/viewall.html Applied to a 305, you'd need a loose 12" 2500-stall and a 3.73:1 at the minimum, and you'd need flat-top pistons.
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
