How can i make a 5.0 tpi into a 5.7 tpi
Old Mar 15, 2013 | 10:51 PM
xendr7wk's Avatar
Car: 91 z28
Transmission: 5 speed
Is there anyways i can make my 5.0 tpi camaro 5sp manual, into a 5.7? Without changing the motor, any parts i could change? An how much could it cost?
Old Mar 15, 2013 | 11:02 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
Re: How can i make a 5.0 tpi into a 5.7 tpi
you'll have to get a 350 block. I mean you could bore out your 305 then stroke it, but even then I doubt you would be even close to 350 cubic inches. Which is useless because you could do that to a 350 block and have yourself a 383
Old Mar 15, 2013 | 11:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Can't bore a 305 out to 350.
Without changing the engine, there isn't a thing at all you can do.
Old Mar 16, 2013 | 12:06 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
double post
Old Mar 16, 2013 | 12:07 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by xendr7wk
make a 5.0 into a 5.7
Buy a 5.7 badge
Old Mar 16, 2013 | 12:24 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
there is a 335 stroker kit
Old Mar 16, 2013 | 06:39 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
I love this message board lol
Old Mar 16, 2013 | 09:07 AM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
The simple answer is no. Not possible. Just get a 350 and go from there.
Old Mar 16, 2013 | 09:25 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There is, and if you use one then you spend more money and do the same or more work to get less results than if you'd just put a 350 in.
Old Mar 17, 2013 | 02:13 AM
xendr7wk's Avatar
Car: 91 z28
Thanks for the comments? But i dont really feel like changing the motor. Now that you said that there is no way to get a 5.7tpi with only changing parts. What are other things i can put on the 5.0tpi, what about a turbo? Or something to get more horsepower? I dont want to change the motor because it only has 80xxx miles and Im the second owner of the car, but well i have a 1986 gmc sierra with a 350, could i just switch the motors or it wont be the same because the sierra is automatic?
Old Mar 17, 2013 | 02:43 AM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
a 305 and a 350 are different engines..how long have you had this car?
Old Mar 17, 2013 | 10:38 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's no turbo kit you can bolt on, and I don't think you're ready yet to build your own.
Spend some time reading the boards to see what other people have done with their cars to get some ideas about what you can do with yours.
Old Mar 17, 2013 | 11:21 AM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
A turbo build can be more complex than an engine swap. Custom fab work. Custom tuning. A good exhaust and headers, k&n filters, port and polish job along with afpr and Bosch III injectors will help your 305. Better gears in your axle too, will make the feeling of an engine swap.
That truck 350 is tbi. Your tpi 305 will out perform that.
Old Mar 17, 2013 | 06:51 PM
VincentZ28's Avatar
If you change the gears, 3.42's are the best way to go. Like mention before, a full exhaust system, gut the air box and just have some fun with those mods.
Grant2k
Jul 10, 2018 04:01 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
