need help with rear main seal cover bolts!
Old Mar 16, 2013 | 10:55 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
I need help figuring out where the bolts go. I have the two small hex heads, a long bolt, spacer, stud and nut.
Old Mar 16, 2013 | 11:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: need help with rear main seal cover bolts!
Stock ;
looking from rear
the stud goes left side , long bolt goes right side and the two short ones go in between
Old Mar 17, 2013 | 12:04 AM
Gsoleski's Avatar
Car: 1984 Z28
Okay thanks. Does that spacer go with the stud then somehow? Also is there suppose to be two studs for the oil pan? Or do the oil pan bolts thread into the cover? I've never built a later model block so I'm not sure
Old Mar 17, 2013 | 02:50 AM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
thats odd...i didnt have a spacer on my rear main seal
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
I'llrocya
Feb 2, 2016 11:43 PM
Reborn756
Sep 4, 2015 03:42 AM
86White_T/A305
Aug 17, 2015 12:16 AM
