Air cleaner help
Old Mar 16, 2013 | 11:56 PM
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
Air cleaner help
So i bought a Pro Form air cleaner because it looks real good, and from everything i have read open element air cleaners are a very good upgrade for a single snorkel like my LO3 has. You can see it below
http://www.proformparts.com/product-...ategory_id/114
It's a 14x3 air cleaner with a 1.5" dropped base.
It fits the spacer flange on the TBI unit fine, but the but the back of the air cleaner sits on top of the plug in the ignition coil, and the stud coming out of the TBI is barely too short for the bow-tie wing nut the air cleaner came with. Is there anything I can do to make this air cleaner fit without turning it into a hack job? Also what do i need to get to plug the hole from the exhaust manifold that the metal tube rain down to from the original air cleaner snorkel? Thanks for all your help.
Old Mar 25, 2013 | 03:04 PM
Jake_92RS's Avatar
Re: Air cleaner help
PLEASE I NEED HALP
Old Mar 25, 2013 | 11:05 PM
HotRodLarry's Avatar
Car: '83 Z28
just find a piece of threaded rod ( available just about anywhere) as long as it is 1/4x20 thread. screw into TB with a nut that matches the thread and measure where you want to cut it.unscrew nut and install air cleaner.
that metal tube that went from the manifold to the air cleaner doesn't need to be plugged up.
Old Mar 26, 2013 | 07:04 AM
Beef's Avatar
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
You can either dent the air cleaner base to clear the coil, relocate the coil, or bend the mounting bracket to tilt the coil for clearance.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
edoff13
Sep 11, 2015 03:55 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
