Smog Removal with headers????
Old Mar 23, 2013 | 07:33 PM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
Hey all,
I broke the bolts off my exhaust manifolds when taking them off when removing my heads on my 1991 pontiac firebird trans am 5.0, they were rusted like no other.
So I am buying headers, probably shorties, but I can't find any with the smog things that go into the original manifolds. Can I just get rid of these and not worry about it. Is it going to effect mpg/engine codes?
Old Mar 23, 2013 | 08:05 PM
Beef's Avatar
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
Re: Smog Removal with headers????
Hooker 2055s have them, and come with a nice Y-pipe.
But yeah as long as you don't have a visual/tailpipe no need to keep it, no codes, no effect at all on driveability. Check the stickies in one of the subforums, probably exhaust, running car without a.i.r. or somesuch. Pull the pump off while you're at it. Should just need a shorter belt.
Old Mar 23, 2013 | 08:20 PM
Ok yeah I did some reading and im just going to get rid of the smog crap. How do I change the PROM to not account for the air coming from smog for the O2 sensor.
Old Mar 23, 2013 | 08:33 PM
Beef's Avatar
Car: 89 RS
Engine: Stock L03
As I understand you don't have to. It pretty much only puts air to the manifolds at startup then it switches over to the cat.
Old Mar 23, 2013 | 08:59 PM
Yeah, it doesn't make that big of a difference but I want to do it, I think I might have figured out what to modify I just have no idea how to mod the chip....
Also what do I do about the smog pump? If i remove it than what belt do I use?
Old Mar 24, 2013 | 09:03 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Look on Ebay for a "smog pump delete" pulley. This will allow you to use the factory size belt, which is what I did.
However, if you search on the site here, you can find the proper routing to bypass the smog pulley. It also requires the purchase of a slightly smaller belt.
You shouldn't have to mod the chip at all. Just leave the EGR "installed", and the relay near it hooked up. The computer isn't smart enough to know the rest of the system is missing.
Old Mar 30, 2013 | 12:11 PM
Hey if I buy headers do most of them come with the hole for the O2 sensor?
Old Mar 30, 2013 | 12:55 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I believe so. I know the 2055's do.
Old Mar 30, 2013 | 04:45 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Both the Hooker 2055's and Dyno Don's emissions headers have the O2 sensor bung welded in place on the drivers side.
Old Mar 30, 2013 | 07:13 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Summit has a really nice header it has the o2 sensor and no air thats whatI am using and they were very very cheap as well.
Old Mar 30, 2013 | 09:15 PM
Could you send me the link by chance? THanks
Old Mar 30, 2013 | 10:16 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
http://www.summitracing.com/search/Y...n/?Ns=Rank|Asc
They are the sum-g9005 they have no air with a o2 sensor
Old Mar 30, 2013 | 10:22 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
If you are just using them as a daily driver there isnt a reason to go with a huge header these will def give you more then a manifold and not lose the low end at all
Old Mar 31, 2013 | 02:10 PM
Thanks!
And yeah I just don't want crappy manifolds anymore
italiano67
Dec 11, 2016 09:21 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
