Transmission lines to radiator?????
Old Mar 27, 2013 | 04:55 PM
wishoradream's Avatar
Car: 1982 Z28
Engine: 388 SBC
Transmission: TH350 Lockup
Having a problem with the transmission lines that run into the radiator, (I bought some of the 5ft sticks of transmission line at Autozone, ran them, and they aren't "tight" in the fittings, there is play in them, this isn't normal is it? I thought it was supposed to "press" the flared end into the fitting on the radiator.....
Old Mar 27, 2013 | 06:02 PM
ex-x-fire's Avatar
Re: Transmission lines to radiator?????
How do the new fittings match up to the old ones?
Old Mar 27, 2013 | 06:10 PM
Car: 1982 Z28
Engine: 388 SBC
The fittings were screwed into the radiator when the guy gave it to me. Evidentally the fittings are too long, so it's not screwing in tight. Just need the standard stock fitting that goes into the radiator I think. Apparently the ones he had in it were elongated for some reason
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
