No Spark
Old Mar 28, 2013 | 10:18 PM
Cars'n'Guitars's Avatar
Car: 1985 Camaro Iroc-Z
Engine: Currently Deciding
Transmission: TH350 Built
Axle/Gears: 3.73 POSI
No Spark
My car has no spark at all, it was tested and shows power in the distributor. Anyone have any ideas of what I need to look at or any suggestions? This problem has been holding me back for awhile now.
Old Mar 28, 2013 | 10:20 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: No Spark
module or coil usually.
Old Mar 28, 2013 | 10:22 PM
Re: No Spark
Both tested fine. Anything else?
Old Mar 28, 2013 | 10:28 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: No Spark
check your grounds real good. any more info on the cars issue?
Old Mar 28, 2013 | 10:36 PM
Re: No Spark
Not really it just has no spark at all, every other electrical thing on the car works except spark, even the clock in the center console works. Where are all the grounds I should look for to check out?
Old Mar 29, 2013 | 03:25 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: No Spark
Is it an hei distributor? How did you test your module? Check the little wire harness inside the dizzy for breaks, make sure the rotor isn't burnt or the cap under the coil isn't damaged or corroded. Check the entire cap for corrosion. Make sure the rotor is turning when the engine is cranked. If all that is good as well as the other parts that you already stated were good I would invesigate the pickup coil.
Old Mar 29, 2013 | 08:17 AM
Re: No Spark
Yes it's an HEI, module was tested 3 times at Advanced Auto. Cap was checked and gone through, I will take a look at those wires.
Old Mar 29, 2013 | 11:41 AM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
Re: No Spark
Definitely verify the rotor turns when you crank over the engine.
Old Mar 29, 2013 | 01:49 PM
Re: No Spark
Rotor turns
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
