proper spark plug gap for hei?
Old 04-10-2013, 10:58 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
What's the proper gap for plugs in a 96 l31 350 with stock vortec heads, gm hei, and a carb? Right now I have them set to the factory block setting of .60, but I've been seeing that .45 is enough for hei. Help? Opinions? Is .60 too much or just right?
Old 04-10-2013, 11:09 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: proper spark plug gap for hei?
.035 to .045
Old 04-10-2013, 11:22 PM
Engine: L31 350
What determines where it gets set
Old 04-10-2013, 11:25 PM
Engine: Lb9
Transmission: M20
A stock hei puts out up to 45kv , there is no need to run a larger gap and over work the coil. This is not a real high compression engine. Run .035 and you will be fine.
Cornholio7979
09-20-2018 02:31 AM
evilstuie
02-28-2016 03:33 PM
LittleFranks
09-17-2015 12:22 PM
g.l.mos
08-22-2015 12:02 AM
Quick Reply: proper spark plug gap for hei?
