88 tbi oil pressure at 0, how to verify if its true
Old Apr 12, 2013 | 03:44 PM
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
hey guys,
so i started my car up today, and the oil pressure said it never raised passed 0. i turn the key off, and you can see the needle drop a bit. turned on, it raises to 0. my question is, is there any way to verify by listening, or checking your oil level or something, to verify if its at 0?
in the past, the needle would get stuck, and i would bang the dash and it would jump up to regular pressure. idk y its not doing it now. so im a bit concerned. any help as always is appreciated
firebird 305 tbi
Old Apr 12, 2013 | 04:46 PM
goliath88's Avatar
Engine: 305 tbi v8
Re: 88 tbi oil pressure at 0, how to verify if its true
nevermind. seems as if the needle is getting stuck or the sender is going bad.
Old Apr 12, 2013 | 05:11 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The senders fail. I'm having trouble getting any of the replacements I've used to last more than a few months. I know I'm running 80 psi but seriously. Replacement parts are getting more and more chintzy. If you looked inside of that big juice can of a sender, you'd see it's a very funky little mechanical device. It's amazing they last at all.
BTW, to verify actual pressure, install a mechanical gauge into the plugged off oil pressure port down by the filter housing.
Old Apr 12, 2013 | 09:47 PM
Beef's Avatar
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
The senders in these cars are terrible. Mechanical is a good option, but makes a mess if it ever leaks. Before you hit zero if you have hydraulic lifters, you will be hearing a lot of valvetrain racket.
Old Apr 12, 2013 | 10:33 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
since its efi, itll turn off the fuel pump. the switch also is a fuel pump cut off. i believe under 7 psi it cuts power. your car would start and shut off alot. stall at stops. etc
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
