AIR Pump lines to Cat.
Old Apr 15, 2013 | 05:03 PM
baker440ex's Avatar
Car: 87 Z28
Engine: Roller 305 LG4
Transmission: NWC T5
Axle/Gears: 9 Bolt 3.27 LSD
87 z28 305/4bbl all stock. I replaced the cat with one that has no provision for the smog pump line. Ive since already removed the air pump and plugged the holes in the manifolds with threaded plugs. (Beginning phases of de-cluttering the engine compartment/with plans to get some dress up parts) Btw I have it registered antique and plan on driving it rarely, maybe take it to a show or two.
Ive hacked away all but the main line that goes to the cat (passenger side) and there's one that goes from the passenger side, over the top of the tranny, and on to the drivers side, back of the motor, where it would branch off to each manifold port. These lines are held in their place by bolts I can't see or reach. (obviously didn't anticipate this) Would they be held by the bolts that go though the tranny into the motor? If so which of the six. If i recall these are accessible using all of my extensions and a universal socket joint. Any insight will be appreciated
Old Apr 15, 2013 | 06:34 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: AIR Pump lines to Cat.
That pipe is bolted to the heads, and the are tough to get at, you will need to wrench them out. The bolt also secures several ground wires, make sure you put those back on.
Old Apr 15, 2013 | 06:53 PM
baker440ex's Avatar
Car: 87 Z28
thanks eseibel, so is there one on each head? the line that goes over the tranny to the drivers side is in there good
Old Apr 17, 2013 | 05:59 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Yes, one on each head.
Old Apr 18, 2013 | 03:13 PM
baker440ex's Avatar
Car: 87 Z28
Ok there's nothing I can do to tighten this nut short of removing the heater box. The driver's side was not an issue but passenger side impossible to reach above, below, wouldn't be able to get a swing on a wrench anyway.
Anyone know the grounds that go to this stud? (I know one is braided copper and comes off the firewall) and there appears to be two others, correct?
Only thing I can think of is cutting these grounds and relocating them somewhere else. Good or bad idea? Assuming they need to be somewhere on the block. Any insight???
I even bought an open ended wrench head that goes onto a 3/8ths socket wrench with no luck. Tried getting it from underneath with a couple 10" extensions, with a universal joint between 2 of them and a universal 14mm on the end, also with no luck. Getting aggravated and need some good insight!!!!
Old Apr 18, 2013 | 07:34 PM
baker440ex's Avatar
Car: 87 Z28
What's inside the black heater box? Even if I take the top half off it I could probably get a wrench in there.
Old Apr 19, 2013 | 07:23 AM
baker440ex's Avatar
Car: 87 Z28
Does anyone know what's inside the black box? If I take the top off Am I gonna uncover a slew of parts or is it hollow?
Old Apr 19, 2013 | 11:16 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
If you have air conditioning, then the AC evaporator coil will be right there.
theshackle
Mar 5, 2017 06:37 PM
mdtoren
Aug 23, 2015 12:52 PM
mcquigg
Aug 13, 2015 02:26 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Kaweh
Aug 9, 2015 02:54 PM
