No Fire to Engine, after shutdown.
Old Apr 21, 2013 | 07:45 AM
Fionnla's Avatar
Car: 85 Camaro S/C
Engine: 350 Vortec 330 HP 650 Demon Carb
Axle/Gears: 3.42 Richmond Powertrax
Friend has 1988 TransAm stock 305 LO3, auto. Had new gas tank and fuel pump installed. Drove car around town shopping. Starting and stopping about 6 time. (about 20 miles). Drove home and stut it down for about an hour. Went to start it up and won't start. Engine turn over normal. Can hear fuel pump kick on and off when turning on ignition. Checked fire to engine, none, Nothing to distributor, plugs, TBI. Installed new coil, still nothing. Removed battery ground wire for 5 minutes. Reinstalled Wire, nothing. All the accesories, headlights, and dash works. No codes before engine was turned off. Any suggestions from anyone would be appreciated.
Old Apr 21, 2013 | 07:51 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: No Fire to Engine, after shutdown.
If you have no "fire" of course it won't run. Work backards. If no spark at the plugs, check for spark at the coil with a spark tester or an old plug.
Old Apr 21, 2013 | 08:35 AM
Fionnla's Avatar
Car: 85 Camaro S/C
Ok, there is no "spark", electical current, juice, ect., to Coil, Spark plugs, Distributor, Injectors, ect, "nothing. Starting and running fine before shutdown.
Old Apr 21, 2013 | 08:45 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
check the ICM and the pick up in the distributor.
Old Apr 21, 2013 | 02:26 PM
Fionnla's Avatar
Car: 85 Camaro S/C
The Car is fixed. Wires to pickup in Distributor broke and shorted the Pickup. Fixed wire, had to replace pickup, running great.
Thanks a lot.
Old Apr 21, 2013 | 04:42 PM
Car: 91 Trans Am
Engine: 355 TPI
no problem man. anything to help
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 9, 2015 05:27 PM
