high idle, running rich, tons of codes
Car: 1991 B4C Camaro
Engine: 350 auto
Re: high idle, running rich, tons of codes
hey I plugged in the v6 memcal, and just so I mention this I am disconnecting the battery every time I play with the ecm... And I still get alot of codes and the light doesn't blink.. Probably should have mentioned this before.. But when I turn the key on, the SES light does flash inc. It flashes once everytime I turn on the key and also when I jump 6 and 12. Dont know if that makes a difference.. Guessing the new memcal won't help? I guess I'll send it back when its in..
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Do you mean you jumpered A and B on the aldl ?
Engine: Lb9
Transmission: M20
The light will come on when you turn the key to the run position. Then jumper a to b on the aldl and you should just see code 12 , three times and it might be followed bye 46 but that depends on what the v6 memcal was from.
Engine: 350 auto
yeah I take a piece of wire stripped on both ends and jump them and with both memcals the light blinks only one time then no more. And I just turn the key on I dont start the car
Engine: 350 auto
are a and b one on top of the other or ome right beside the other I think I did it wrong I did it one on top of the other.
Engine: Lb9
Transmission: M20
A and b or on your right side as your sitting in the drivers seat top row the last 2.
Engine: 350 auto
okay I'm home and what's in now is the new ecm and my old memcal. The code 12 blinks constantly. Nothing else but code 12 over and over again. Does this mean I'm cured if my ecm problems? Can I send my new memcal back?
Engine: Lb9
Transmission: M20
The test now is with the new ecm and the aujp or anjf memcal and it just will blink code 12 three times ?
Engine: 350 auto
the test now is the new ecm and my old aujp memcal that was origionally in my old computer. The code 12 blinks nonstop it doesn't stop blinking code 12.
Engine: Lb9
Transmission: M20
But the code 12 is just in diagnostic mode ?
Engine: 350 auto
just when I jump the A and B things and turn the key on without the engine running. It blinks code 12 constant.
Engine: Lb9
Transmission: M20
That's they way it should be. I'm not sure if your scanner just shows codes or codes and data but sounds like the issue is resolved. Is the car still idleing high and rich ?
Engine: 350 auto
I let the car idle for about 15 minutes and just got a code 23 which I looked up. Its low temp. At manifold air temperature sensor or tps but I replaced both of those parts...
Engine: 350 auto
okay drove my car today about 15 minutes and then another 15 minutes a couple hours later. On my first drive the car got a little hot. Keep on mind my idle is still high. The surging stopped for the most part though. I have two codes now. 23 which I stated above.and 45 which is o2 sensor rich I replaced all the parts that are stated in my codes. Only thing I can think of is that when I replaced the tps is didn't set it right. Or when I plugged my wires in the manifold air temp sensor they are in the wrong sides maybe I should flip them? Let me know
Engine: Lb9
Transmission: M20
http://chevythunder.com/mat_code_23.htm
If he leads of the mat were flipped kinda hard when there keyed it would not matter its just a thermistor . the mat low reading can cause the rich condition.
Engine: 350 auto
could you give me a link to a good one? On eBay? Or is that something I could buy at advance
Engine: Lb9
Transmission: M20
I have a fluke but just for basic testing a cheap vom will work fine. I think harbor freight is even still giving them away until tomorrow. I went there last week to get some glass media and the lady tossed one in my bag.
Engine: Lb9
Transmission: M20
Just go get a cheap digital one . Looks like I was wrong on the date not sure why the lady tossed one in my bag but oh we'll lol. I like my fluke 78 but doesn't sound like you need all the bells and whistles.
http://widgets.harborfreight.com/wsw...1002&hftref=cj
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
One comment I will make is that I have had issues before on newer systems using a DVOM with too low input impedance. If the input impedance of the meter is too low, you will not get an accurate reading and it can even affect system operation if it brings signal voltage down when connected.
At GM, and Tuned Performance knows this, we were cautioned to use a DVOM with no less than 10Megaohms per volt input impedance. As far as I know, only better units comply with this specification, such as the Flukes.
At Chrysler, I even had issues with my 10M ohm/volt lab scope causing interference and phony readings on portions of the newer Chrysler systems. Be sure to read the specs on the Actron meter you bought and be sure that it is 10Megaohms per volt. Otherwise it may not be compatible with EFI systems.
Engine: 350 auto
the diagram of what to check test is kinda confusing me do I check the plug for the sensor first then if its too low where do I test?
Engine: Lb9
Transmission: M20
Good point doc, see how much I forgot lol . The trouble tree is referring to the 5 volt reference coming from the ecm pin f16. With the key on and the mat unplugged at the harness the tan wire should have real close to 5v.
Engine: Lb9
Transmission: M20
Unplugging the mat pigtail first with the key on check the tan wire for voltage ground you vol negative lead directly to the battery. If its close to 5v take you negative lead of your vom and hook it to the mat black wire lead the voltage should read the same as before.
Engine: 350 auto
mine is the actron cp7672 it was 20$ and does 200 mV - 1000V DC voltage
2 V 750 V AC voltage
200ua-200mA, 10A DC Current
200-2000K resistance
Engine: 350 auto
I figured it out so with the red lead plugged into the tan wire and the negative terminal its about 4.9.with the tan and the black wire both probed its 4.9.what do I test now? Only thing I can see wrong is that maybe the terminals weren't touching the sensor all the way. I had to stick the red probe into the plug pretty deep.
Engine: Lb9
Transmission: M20
Now turn the meter to ohm setting and check the resistance on the mat pigtail leads.
Engine: 350 auto
I think ohm setting is the setting with the little horseshoe.. Well it just stays at one and doesn't change when I probe them (red with tan black with black)
Engine: Lb9
Transmission: M20
Put the meter to Ω 20k setting
4. RESISTANCE MEASUREMENT
a. SettheSELECTORswitchtotherequiredresistanceW(ohms)position.
b. PlugtheBLACKtestleadintotheCOMinputjackonthemultitester.
c. Plug the RED test lead into the VWmA input jack on the multitester.
d. Connectthetestleadstothecircuitundertest.
Engine: 350 auto
well I'm doing that and when the probes are on them it stays at 1. But when I take the probes off, it flashes between 14-20 for a quick second.
Engine: 350 auto
I know it seems like I'm doing something wrong but this is really what's happening...it will read the volts but not resistance..
Engine: Lb9
Transmission: M20
Try a lower scale
Engine: Lb9
Transmission: M20
Engine: 350 auto
i dont see how that gives you a reading theres no current going to it.. Im not getting a reading doing what your diagram shows...
Engine: 350 auto
I was origionally doing the tests in the plug that goes into the sensor... There is no reading the way your picture is for me... Unless my plug isn't touching the sensor all the way which might be the problem.
Engine: Lb9
Transmission: M20
You will get a resistance reading across the thermal resister. The malfunction 23 code indicates high resistance in the mat circuit. Unless there is a break in one of the pigtail wires or connection issue at the mat or the mat is bad.
Engine: 350 auto
the mat is the gold sensor under the intake plenum right? Or is that the coolant temp sensor?
Engine: Lb9
Transmission: M20
The mat us under the plenum same part number for both sensors. 213-4396 acdelco
Engine: 350 auto
it must be when my wires fell out if the clip it never set right because i get the reading when i touch them straight to the sensor... Ill have to buy that new wire cluster with the two clips on them.
Engine: Lb9
Transmission: M20
The Packard mat terminals are listed as the pull to seat connecters.
http://www.corsa-technic.com/categor...category_id=81
