TPI Bolt problems and swap
Old May 3, 2013 | 01:51 AM
lethaldomestics's Avatar
I searched a little with no luck
1987 350 Tpi Firebird T/A
Can i change out the torx head bolts for regular bolts? I am just concerned about where the intake manifold attaches to the heads. I don't really like the torx. i stripped one out real easy then had to drill the head off it and remove it with vice grips.
On another one the head snapped off completely and it wont come out even with vice grips and pb blaster. Tried a crafstman easy out with no luck. Tomarrow i plan to helicoil unless anyone has a better idea.
Thanks for your time. This site has always been a valuable resource.
Old May 3, 2013 | 04:04 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TPI Bolt problems and swap
Yes
Allen head cap screws are the best replacements
Old May 3, 2013 | 05:40 PM
so they have to be allen? I cant use standard bolts fome an older 350?
Old May 3, 2013 | 10:01 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Was just searching parts on ebay ... entire set, $34
http://www.ebay.com/itm/TPI-Complete-Top-End-Stainless-Bolt-Kit-85-92-Camaro-Corvette-Tuned-Port-Plenum-/181013781882?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a25431d7a&vxp=mtr#ht_475wt_1091
Attached Thumbnails TPI Bolt problems and swap-t2ec16dhjg-e9nm3ri5sbqkhfmby-60_57.jpg
Old May 3, 2013 | 10:02 PM
Car: 90 Iroc Vert
Engine: 5.0L
Found on ebay - entire set $34 - click on the picture above ... links to ad
Attached Thumbnails TPI Bolt problems and swap-t2ec16dhjg-e9nm3ri5sbqkhfmby-60_12.jpg
Old May 3, 2013 | 10:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Check out the clearance @ intake manifold; there is little room to get a socket on a hex head bolt
Old Jul 10, 2013 | 01:01 PM
Sorry for the delay. Replaced all bolts with high grade hex bolts no issues. 8 bucks out the door.
1984HO
Mar 19, 2021 11:59 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
