1988 formula tpi 5.0 won't idle with maf plugged in
Old May 3, 2013 | 07:15 PM
James ws6b's Avatar
Hi I have a 1988 firebird tpi 5.0 been sitting for a little over 10 years I just replaced fuel pump and filter and did a tune up, after I got it started I noticed that the maf wasn't plugged in. I plugged it in and it ran ok when I restarted tho it would not idle and was not throwing a code. It is still doing this and now it is also now revving high when I first start it and it will not idle with or without it off I think the timing is just off for that but it's worth a shot asking help would be appreciated thanks!
Old May 3, 2013 | 07:19 PM
James ws6b's Avatar
Re: 1988 formula tpi 5.0 won't idle with maf plugged in
The injectors are all good they ohm at 16.5 and all wires cap rotor ignition coil and plugs were replaced just confused on why it runs better without it in and if I should get a new maf
specialized
Jun 18, 2022 09:26 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Randomtask2
Aug 13, 2015 01:57 AM
Sanjay
Aug 12, 2015 03:41 PM
