HELP!! Car wont start..
Old May 3, 2013 | 07:45 PM
Soon2beBad91Z28's Avatar
My 91 Camaro z28 305 wont start. The battery and starter are fine. I started a few times but ran rough. It bogged and didnt want to idle smoothly. Is this a computer or fuel issue?
Thanks for any input fellas, I need help
Old May 3, 2013 | 07:56 PM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
Re: HELP!! Car wont start..
When you turn the key, can you hear the fuel pump kick in? If you have the door open, you should hear the whine of it kicking in.
Is it getting fuel up front? Injectors- how old are they, and are they clean?
Has it been tuned up lately- I've had something as simple as a cap and rotor keep a vehicle from running.
Sometimes it's best to start with the simple things first, and go from there.
Old May 3, 2013 | 08:00 PM
I have done a tune up. Ill listen for the fuel pump. No idea on the injectors. Does crank but it wont fire up
Old May 3, 2013 | 08:19 PM
ok it started up. it may be a bad coil
Old May 4, 2013 | 04:41 AM
Hope that's all it is. Make sure you get a good quality one- I've had good luck with Napa- nothing but issues from Carquest/Autozone.
I had a vehicle that the magnet cracked in several places in the distributor and caused it to run rough, or not want to start.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
