running hei with only 1 weight?
Old May 7, 2013 | 10:20 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
What exactly would this do to a motor?
Old May 7, 2013 | 10:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: running hei with only 1 weight?
The centrifugal advance would not work lack of timing lack of power
Old May 8, 2013 | 05:56 AM
Engine: L31 350
Makes since. I pulled my distributer out of my motor to fix an oil leak and put a new cap and button on my distributer and when I took off the button I noticed that its missing a whole weight and spring.
Old May 8, 2013 | 01:10 PM
Engine: L31 350
So just to be clear this wouldn't have hurt my motor would it
Old May 8, 2013 | 01:21 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
No it won't hurt your motor (unless the weight or spring
fell down into the motor internals).
You just won't have any mechanical timing advance just the
vacuum advance.
The only down side would possibly be hesitation or lack of
performance to a small degree.
Old May 8, 2013 | 01:49 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Continued operation with one weight missing would lead to destruction of the dist shaft and housing due to running the shaft out of balance.
Old May 8, 2013 | 02:21 PM
Engine: L31 350
Distributer is pulled out of the motor. I was just wanting to make sure I didn't hurt my motor while it was running before I found it.
Old May 10, 2013 | 08:12 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Weight and spring advance curve kits are available aftermarket.
Old May 10, 2013 | 12:27 PM
Engine: L31 350
I'm just buying a new distributer since I need the kit and a new cap, button, and modular
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
midias
Aug 15, 2015 05:07 PM
