87 lg4 high idle
Old May 8, 2013 | 01:14 PM
87FBomb's Avatar
Car: 1987 Firebird
Engine: LG4 305
87 lg4 high idle
my 87 ccc firebird idles high while in park and neutral and while im driving it continues to accelerate iv checked for vacuum leaks and cleaned up some of the previous owners "work" but i cant seem to find the cause of this my patients and my brake pads are wearing thin
Old May 8, 2013 | 01:57 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: 87 lg4 high idle
Could the idle stop solenoid be mis-adjusted? Does the car have functional AC? If the AC compressor is disconnected or inop and the AC switch is on the idle stop solenoid will force the idle high. Is the choke opening fully? The fast idle cam could be stuck.
Old May 8, 2013 | 02:19 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Assuming that adjusting the curb idle set screw does nothing and that there are two throttle return springs connected and they're still tight?
When it's idling high, ensure that the idle lever is resting on the curb idle set screw. If it is not, find out what is holding it open. Could be stuck fast idle under the choke, idle bump solenoid or worn throttle bushings.
If it's resting correctly, check for vacuum leaks. I like to plug EVERY port then with a dwell meter connected, reconnect each port and observe for change in idle quality and dwell reading.
Old May 10, 2013 | 11:05 PM
likwidmetaldeth's Avatar
Car: 87 firebird
Engine: lg4
my car just had a similar problem and the cruise control cable was binding, causing the throttle to open
Old May 11, 2013 | 12:26 AM
Kumicho's Avatar
Car: 1988 Trans Am (white paint)
Engine: LB9 305 CID V8, TPI
Transmission: Stock TH-700R4
I'm almost certain the problem lies with the throttle plate hung open, as Naf suggested. When you first start the car for the day, cold, observe the behavior of the carb's components. If it's off kilter, I would suggest simply rebuilding the carb - about $30 and the rebuild writeup from Naf,
https://www.thirdgen.org/forums/carb...-ccc-qjet.html
,as well as the stickies under the Carburetor forum will set you straight - helped me well enough with my E4ME Qjet...can't thank the guys here on TGO enough.
GTAman
Sep 21, 2015 09:57 AM
db057
Sep 4, 2015 07:57 AM
IROCtometal
Sep 2, 2015 02:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
