Correct Motor Oil Level
Old May 10, 2013 | 10:26 AM
rongreen's Avatar
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
I am about to install an OEM oil tube and matching oil level indicator (dip stick). I will have to bend the DS for clearance.
Will bending change the accuracy of the dip stick as long as the DS seats properly? I think nothing will change please correct me if I am over looking something.
Thanks in advance
Old May 10, 2013 | 11:58 AM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: Correct Motor Oil Level
Yes and no, it depends on where you bend it. Geometrically, if you bend it within a few inches of the tip, it could alter how far the tip extends into the oil, however if it's the stock length and you are bending it further up on the stick to facilitate removal and installation, it will not alter the reading. Any bend after the stick has extended past the guide tube will change how far it goes into the oil. I would not be overly concearned with it though, change your oil and put in 4.5 quarts (with prefilling the filter) run the engine, and check where it is on the dipstick. That should be your baseline reading, and you can mark the stick (either stamp it or drill it) so you are referencing the proper flid level on all subsequent checks.
Old May 11, 2013 | 12:11 AM
rongreen's Avatar
Thanks Berlinetta, I will be bending it about where the header bolts to the heads. Sounds like I should be ok. I wanted to be sure before bending a new dealer's part.
I love this site!!
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mizz0313
Aug 12, 2015 06:45 AM
