85 camaro wont start neutral saftey?
Old May 12, 2013 | 04:48 PM
racingbob8's Avatar
I have a 85 Camaro and I started it than shut it off and went to restart and nothing.i can jump selinoid and and will start. so I checked neutral start swith wires, the yellow and the purple wires have power when trying to start. any helpful ideas
Old May 12, 2013 | 09:36 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 85 camaro wont start neutral saftey?
But does the wire on the solenoid that comes from the NSS have power when the key is in the START position?
Old May 17, 2013 | 05:59 AM
racingbob8's Avatar
no power t starter solenoid
Old May 22, 2013 | 04:24 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
It's odd that there is no power on the purple wire at the starter when it has power at the NSS. Repeat the power check on that wire and verify that you have a good ground on your test light or DVOM. Check the connections at the solenoid for corrosion or burning. You're talking about a large gauge wire that doesn't normally fail. More likely poor connection or just a bad solenoid.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
92camaroJoe
Aug 13, 2015 06:07 AM
cRoe4
Aug 7, 2015 08:46 PM
