1182 crankshaft - one or two piece rear main?
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Hey guys,
I found someone selling a load of engine parts. He has an 880 block and an 1182 crankshaft. I can't find much info on the 1182 (or I'm not searching right), is that a one piece or a two piece rear main seal? I'm on the prowl for 350 components so I can start a mild build.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1182 crankshaft - one or two piece rear main?
(PN-3941180) (Casting #-1182) is a 1053 forged steel crank, with a 3.48" stroke and 2.45"/2.10"
journals, not nitrided. This crank is used with a two-piece seal.
Engine: Lb9
Transmission: M20
Car: 1989 GTA
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
