385 ci build for swap into 3.1L bird (cont'd)
Old May 18, 2013 | 04:14 PM
Seanphelps321's Avatar
Car: 1992 Firebird
Engine: 3.1L(swapping in 385)
Transmission: Looking for T56
Axle/Gears: Looking for 3.73 posi
Hey everyone,
Last summer I started a 385 engine project for my 1992 firebird. Right now I'm still planning the build a little bit. Here's the thread from last year if you're interested:
https://www.thirdgen.org/forums/tech...ching-cam.html
Anyway, I'm planning on bringing the engine to a performance shop to have the short block built and balanced professionally. I guess my first DUMB question of this summer is: What ALL does the shortblock include? I have the rot assy including pistons, rings, wrist pins, rods, crank, rod bearings, crank bearings. I'm asking this because when I bring it in I don't want to leave anything out. I don't want to bring in the damper or flywheel to be balanced WITH the rot assy though.
As far as my limited knowledge goes , that's all I can think of that might be better off for the professionals. Please correct me if I'm wrong though.
Old May 21, 2013 | 01:58 PM
Car: 1992 Firebird
Re: 385 ci build for swap into 3.1L bird (cont'd)
Anyone to confirm this? If I forgot to buy a part then I want to do it soon.
Old May 21, 2013 | 04:23 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Your short block will be the whole rotating assembly, and if they are going to balance the crank then you'll need a neutral balance flexpate and damper Sounds like you have everything you need as long as the balancing is all internal.
Old May 21, 2013 | 09:25 PM
Car: 1992 Firebird
Thanks. I just wanted to confirm. I'm going to try to get that done so I can start putting together the top end.
Old May 26, 2013 | 04:15 PM
Car: 1992 Firebird
Would something like this timing set be adequate?
http://www.summitracing.com/parts/hrs-94303
Also, what should I look for when it comes to a distributor? I see some going for 4-500 and other for under 100. I don't really understand the differences in them.
Can provide more engine info if needed
Orr89RocZ
Apr 25, 2016 08:28 AM
jharrison5
Aug 19, 2015 05:53 PM
cstrobel65
Aug 15, 2015 10:19 AM
sreZ28
Aug 14, 2015 07:48 PM
92projectcamaro
Aug 6, 2015 01:20 PM
