Primary fan turns on when turn key on
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Noticed today I heard my driver's side coolant fan turn on when I turned the ignition to the on position before cranking. Started engine and immediately got SES light. So I got my scanner out and hooked her up to the OBD port. It gave me a reading "unable to detect source"..Then tried the paper clip routine and was unable to to get the display to flash at all.
Anybody out there have any ideas on what may happened here ? Did my ECM take a dump ?
Thanks in advance....
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Primary fan turns on when turn key on
sounds like a bad ecm or the memcal not being seated.
Engine: 5.7 ltr.
Engine: Lb9
Transmission: M20
Double check the ground behind the cylinder head , but it sounds like your in limp home mode.
Engine: 5.7 ltr.
Thanks for the quick reply...And yes I did. I checked both heads where the grounds are bundled and bolted to the rear of them. I could not find no loose wires. Is there a ground coming off the ECM under the dash ?
Engine: Lb9
Transmission: M20
There are a total of four grounds for the 165 ecm and all connect to the back of the cylinder head. If I remember correct one is the o2 ground, injector ground , ecm ground and tps, cts, mat ground. no difference with the spare ecm ?
Engine: 5.7 ltr.
Thanks for your time.
Engine: Lb9
Transmission: M20
That and the no ecm communication sounds like it went out to lunch.
Engine: 5.7 ltr.
