1983 z28 tbi c/f injection
Old May 22, 2013 | 04:15 PM
loujon's Avatar
I did not know where to post this question. I need a fuel pump for 83 z28 c/f injection. it is located in the tank. I don't know what brand of fuel pump to buy. when I go to parts stores online, they don't tell me what psi rating is. question: what brand and pressure rating electric fuel pump should I buy for stock z28 as described above.
Old May 22, 2013 | 05:17 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 1983 z28 tbi c/f injection
the stock crossfire fuel pressure is regulated at the TBI to ~10-13 PSI,IIRC the original pump is rated at around 20PSI deadhead.I have a walbro turbine in my crossfire,but it was originally meant for a chrysler application and took some minor modifications to fit.I think walbro is good,AC delco used to be good but i have heard recent delco pumps are just chinese junk in a GM box...A TPI pump is often used as an uprade on crossfires-pump pressure is higher,but pressure regulator will keep pressure regulated to original pressure setting.Only minor modifications are needed to install a TPI pump on a crossfire.Main thing is not to install a junk chinese pump
Old May 22, 2013 | 08:02 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
You'll have a hard time today finding a parts manufacturer, Walbro included, that doesn't have a manufacturing facility in China. Actually, after a few bumps in the beginning, quality of parts manufactured overseas is getting to be much better, thankfully. There are very few parts made in the USA anymore. Only some of the better aftermarket pieces. Hopefully, this trend will turn around in time but as long as value is mistaken for low price, things will stay as they are.
Old Aug 29, 2015 | 12:37 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Any updates ?
Cleotiz
Jan 6, 2018 08:56 PM
toronto formula
Nov 10, 2015 06:17 AM
AilmentDiavolik
Interior Parts Wanted
Sep 9, 2015 02:17 AM
z28addict8490
Sep 5, 2015 03:56 PM
3tas4me
Sep 4, 2015 01:45 PM
