At my wits' end!!
Old May 23, 2013 | 04:26 PM
Soon2beBad91Z28's Avatar
At my wits' end!!
I have a 91 camaro 305 tpi that has trouble starting intermeittenly. It will run fine then sometimes randonly die: the rpms will slowly drop until it stalls. Sometimes I go to start it and it will crank but not catch fire. I can start it up with starter fluid but then it dies, even if i hit the gas.
What Ive switched out:
IAC
TPS
Fuel pump relay
Coolant Temp sensor
O2 sensor
Fuel filter
Spark plugs, wires, and cap and rotor
I checked codes and only got a code 12.
I believe its a fuel delivery issue but is electrically related. Its a very intermittent problem. I suspect it could be a fuel pump but it's hard to tell.
If anyone could give me an idea where to go, that would help me so much!!
Old May 23, 2013 | 04:27 PM
Re: At my wits' end!!
Btw, TPS and IAC valve are adjusted
Old May 23, 2013 | 05:25 PM
Burnworthy's Avatar
Car: 2015 2SS 1LE
Engine: LS3
Transmission: TR6060
Sounds like a similar issue I had AFTER I had my fuel pump replaced.
The shop that replaced my fuel pump had jerry rigged it rather poorly so under hard braking something was coming loose and my pump would shut off.
The starter fluid is gonna get it started initially, but it sounds like you're not getting any fuel delivered to keep the engine running.
Have you turned the key and listened to hear if your fuel pump is kicking on?
Old May 24, 2013 | 10:43 AM
I checked the pressure at the schrader valve, it shot gas out. I can hear my pump prime.
Old May 24, 2013 | 11:38 AM
witnlyn's Avatar
Car: 54 Chevy Sedan Delivery
Axle/Gears: 3.73 posi
Check oil preasure switch that also supplies power to fuel pump
Old May 24, 2013 | 11:55 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
test your injectors too. Test for ohms
Old May 24, 2013 | 12:31 PM
I forgot I replaced that OPSU as well. Tested the power and the pump ran fine. I will check injectors later today. How do I check them?
Old May 24, 2013 | 12:41 PM
ninetyone's Avatar
Axle/Gears: 3:42
Old May 24, 2013 | 01:55 PM
southbay08's Avatar
If they test at 12ohm or less either cold or hot, they will need to be replaced
www.southbayfuelinjectors.com
516-442-4707
Old May 24, 2013 | 07:05 PM
Ok but lets divert from the injector idea. It seems there is something in the computer that is telling it to cut out the fuel pump. Could a bad fuel pressure regualtor cause that?
Old May 26, 2013 | 05:50 PM
Now the car doesnt even start. I think my fuel pump had a very slow death, I will put in my new one in the next day or so
J-money
Jan 4, 2019 09:45 AM
92projectcamaro
Jan 18, 2016 08:00 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Sep 7, 2015 09:41 AM
SG91camaro
Sep 5, 2015 10:27 PM
