What is this going into intake manifold?
Car: 1991 Z28
Engine: 383 Stroker with edelbrock heads
Axle/Gears: 4.10 Posi
This is located between the distributor and throttle body and it has a hollow black wire coming from it that was cut in half trying to figure out what this wire is? cause my car is idling and running like crap all of the sudden please help!!
Car: 1991 Z28
Re: What is this going into intake manifold?
so with that being cut in half that could be why my car is idling rough and will almost stall at heavy throttle?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 1991 Z28
You nailed it it's having trouble idling, and when you accelerate it stalls or pings really hard
Car: 1992 camaro rs
Engine: 92 350ci carbed
Transmission: 700r
Axle/Gears: Stock 10 bolt 2:73 gears 😭
Vacuum, just get a new line and you should be fine as long as that's the only problem.
Car: 1991 Z28
So today i plugged that vacuum line and now i'm getting backfire through the tbi, flames and etc...
Engine: Lb9
Transmission: M20
check your timing with the est disconnected
Car: 1991 Z28
EST? and i did have a distributor change recently, the car was running but sounded like crap and now after plugging that vacuum the right way i get flame through throttle body
Car: 1991 Z28
so basically disconnect the wiring to the distributor and re find tdc
Engine: Lb9
Transmission: M20
warm the engine up and turn it off. Disconnect the est and restart the engine . Loosen and adjust the distributor while using a timing light. I believe the L03 is set to tdc . If your emissions tag is still present it will state the timing spec.
Car: 1991 Z28
so you cannot adjust the timing with the electronics hooked up to the back of the distributor?
Car: 1992 camaro rs
Transmission: 700r
It's not supposed to be plugged its supposed to be reconnected
Engine: Lb9
Transmission: M20
Car: 1991 Z28
i didn't know that sorry i don't know much about timing i had those connected when i was trying to find tdc
Car: 1991 Z28
Engine: Lb9
Transmission: M20
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
