Daul Snorker ram air+ Fog light Ram Air? Pics inside
Old Jun 9, 2013 | 04:25 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Ok guys, here is one of my crazy ideas for my 5.7 Iroc.
I have been running a home made ram air setup similiar to Hawks. It simply runs from behing the fog lights up to the TPI snorkel. I ran this setup without my fog lights installed for a while. It provided a great gain over stock at speeds above 40mph. I later installed the fog lights and noticed that the ram air wasn't nearly as effective.
So what if I installed a Dual snorkel ram air setup that drew air into the high beam lights, that integrated into the fog light ram air?
Here is the concept I came up with
So I am integrating this
And this and have them connect to the main intake pipe, coming out the TPI plenum.
I also have a way to make this look 100% stock on the exterior.
My main concerns:
- if their are any negatives of forcing so much air into the intake. Such as tune and what not.
- I will need two more air filters behind the headlights. Wouldn't this kill performance under 40 mph even though I would use K&N Filters.
What are your thoughts? Think I will gain enough extra power to make it worth the time and fabrication?
Old Aug 22, 2014 | 01:19 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
Re: Daul Snorker ram air+ Fog light Ram Air? Pics inside
Did you ever try this out? Seems like a great idea.
Old Aug 22, 2014 | 02:01 PM
Axle/Gears: 4.10
Nope, ended up doing an LSX swap. I am still running the stock TPI intake, but will be ditching that, and designing a new ram air setup for the lsx.
As far as the method that I originally posted, its gotta work. I'd imagine at 60-80 mph it would probably build up a pound or two of boost.
jaridjohn
Jul 8, 2024 03:49 PM
project89
Sep 24, 2015 06:38 AM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
