Timing chain recommendations
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
I need a new timing chain set. Anyone recommend one that will fit behind the stock cover and work with a comp cam? (89 5.7)
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Timing chain recommendations
stock replacement chains will get the job done and last a good long time..
Car: 89 Black GTA
Transmission: 700
How about this one: 9-3146 http://www.jegs.com/i/Cloyes/220/9-3146/10002/-1
Would you get the thrust bearing with it?
Car: '88 Trans Am
Engine: 5.7L TPI
You can also use comp cams or edelbrock.... aslong as you use a double roller you will be fine. The stock single roller chain will work but for a few extra $$$$ a double roller is the way to go.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Used the Comp 2136 on a stockish engine recently. It did fit behind the timing cover, and it did not touch the block. But I think it would be prudent to check the clearance before you put it back together.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
They are not all the same. Get the ones made for factory oem roller blocks
ambainb
Apr 25, 2016 09:21 PM
