seized 305 need help
Old Jun 12, 2013 | 06:14 AM
ak99669's Avatar
i recently aquired a 83 z28 with a t5 for 300$, it has a siezed bottom end , i have a few questions since the motor is seized how do i take the bolts out of the clutch? iv only pulled 1 sbc and i remember rotating the engine too get at the bolts, should i pull the engine and tranny together? or can i seperate them with the motor seized up still in the car, please and thank you for the help, incl picture of the car and my 85 se with 305/700r4
Attached Thumbnails seized 305 need help-969890_518406664875955_940891650_n.jpg
Old Jun 12, 2013 | 06:29 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: seized 305 need help
You should be able to do it either way if you have a good set of tools.
Old Jun 12, 2013 | 06:43 AM
ex-x-fire's Avatar
The 5 spd will slide out of the clutch, then remove the bellhousing. Its not like a torque converter.
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
