2.8 multiport v6 in my camaro
Old Jun 16, 2013 | 02:06 PM
BLHJR35's Avatar
Car: 89 Camaro
Engine: 2.8 multiport v6
Transmission: 700r automatic
Hello to all,
here is my problem start to finish.I have a 89 camaro with a 2.8 multiport engine.when i got the car, I went to change the plugs and wires and found that the car was running 180 degrees out.It was wired to run and run decent, but lacked some power so i pulled the dist. and set it back right to chevys specs. But now it wont start and pours gas from the trottlebody.Its like it floods itself out.Does anyone have any input on this? It would be greatly appreciated!
Old Jun 16, 2013 | 03:04 PM
ex-x-fire's Avatar
Re: 2.8 multiport v6 in my camaro
Pull #1 spark plug & feel for compression as you turn the engine over by hand. Turn the engine over by hand till the timing mark on the balancer is at zero on the timing tab, pull the dist. cap & look if the rotor is pointing towards #1. If not then Pull the dist. & reposition to #1, the reset the timing by following the emissions decal.
Old Jun 16, 2013 | 04:22 PM
BLHJR35's Avatar
Car: 89 Camaro
Did all that.Will act like its trying to start but just turns over as it just pours gas out of the throttlebody.
Old Jun 16, 2013 | 06:03 PM
ex-x-fire's Avatar
Is this is the engine in your car? Gas is pouring out of the throttle body? Stop cranking it, disable the ignition now, you need to figure out whats bleeding down. Stuck open injectors, a cts giving cold signals to the ecm (like its -40* outside), a very bad pressure regulator.
Old Jun 16, 2013 | 08:50 PM
BLHJR35's Avatar
Car: 89 Camaro
how do i check all that out?The car run ok before i made the change to the dist.
Cleotiz
Jan 6, 2018 08:56 PM
Zane Story
Oct 8, 2015 12:40 PM
bryaniskoo
Oct 1, 2015 03:18 PM
usafirebird
Sep 29, 2015 11:58 PM
rjcme
Sep 5, 2015 01:23 PM
