SES light, code 33
Car: 1988 GTA Trans AM
Transmission: 5 speed
SES light, code 33
Good day all, my bird threw a code 33 this morning, just wondering what I should check first, before replacing any relays or sensors
Does anyone have a link to test the maf power and burnoff relays and the maf itself?
many thanks in advance
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: SES light, code 33
many, many thanks, i will go through this tonight, I do know i have a hypertech, will check the number as if that is the issue maybe i will just get a new chip.....I am currently in process of getting a moates adapter through ebay, but the seller has now doubled the shipping cost, i am fighting it, may end up finding a diff seller
Engine: Lb9
Transmission: M20
Hyperjunk has done three different setups for tpi. At first they used gm memcals and scribed vc on the side. You can still see the I/o buffer and netress with the numbers 16055375 and 16055376. the second one the eprom is above a chip th had made and the binary file is encrypted . It has a black glossy goo covering the pcb that you can see through the one acess window. This is the one I have seen the most issues with. The third is what the produce now is a piggyback adapter like the moates.net g1 .
eightsixseven
Dec 16, 2024 01:50 PM
