Walbro Fuel Pump Question
Old Jun 18, 2013 | 02:22 PM
mojo_jojoe4's Avatar
Car: 1991 Firebird Vert
Engine: 383 L98/LT-1
I have a 91 Firebird, but the motor in it isn't the stock one and I have no idea what year, plus I had a converted LT1 intake put on. I know it was a 255 Walbro. A couple weekends ago it wouldn't start anymore, I'm assuming my fuel pump went out, hooked up a gauge to the valve on the rails and it read 0 pressure. My question, if I order another 255 Walbro, will it be a direct swap? I don't want to drop the tank, look at the part number, order it and wait, I'd like to order it now and install it ASA it comes in.
Old Jun 18, 2013 | 02:27 PM
Tx 91Z28's Avatar
Car: 91/Z28/69SSCamaro/72Cheyenne
Engine: 350/350/350
Transmission: 700r4/400/350
Axle/Gears: 3.23/4.56/4.11
Re: Walbro Fuel Pump Question
It will work just fine BUT have you checked the fuel pump relay ? Can you hear the pump at all ? Does it have power going to it ?
I put a BBK in mine and all I had to do was adjust some wires going it.
Old Jun 18, 2013 | 02:33 PM
Yes, the pump will kick on, and there is fuel up at the shrader valve when I press the nipple.
Old Jun 18, 2013 | 06:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I'm assuming my fuel pump went out, hooked up a gauge to the valve on the rails and it read 0 pressure..
Have you done the full fuel diagnostics (like checking the regulator ) to confirm it is actually a pump pressure problem ?
Old Jun 18, 2013 | 08:36 PM
How do you do that?
Old Jun 19, 2013 | 01:45 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
it wouldn't start anymore.
How did you decide fuel was the problem?
Did you check for both spark and fuel?
Pump only runs for 2 sec when key turned on then it turns off.
You need to jumper the pump relay so the pump runs full time BEFORE doing any pressure tests.
Old Jun 19, 2013 | 03:28 PM
OK, I'm stupid, how do you do that?
Old Jun 19, 2013 | 03:35 PM
Tx 91Z28's Avatar
Engine: 350/350/350
1st off your not stupid, stop putting yourself down. Everyone had to start somewhere. Vettoz will be along later and explain it. BUT meanwhile find the fuel pump relay and unplug it. Check which wire has voltage coming in and jump it to the wire going out thusly bypassing the relay, I don't know the exact wires but that is the theory. This wil llet fuel pump run while you do pressure test. One of the supreme boys will be along shortly!
Old Jul 31, 2013 | 08:04 AM
OK, so I replaced the fuel pump and put gas in the tank and it starts up like a dream. I hooked up a FP gauge and when the key is turned, the pressure shoots up to like 80PSI then when started, it goes up to 100PSI and stays there.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
