Metal in oil pan
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Metal in oil pan
Can anyone tell me what this metal piece is, I found it in the oil pan while l changing a gasket. Underneath the underneath the engine looked good and when I had the heads off everything looked good up top. It is magnetic
Edit: sorry for bad spelling I think I fixed it I posted from my phone using voice because my hands were filthy.
EDIT: it kinda looks like a piece of inner valve spring.
Car: 1985 Camaro Iroc-Z
Engine: Currently Deciding
Transmission: TH350 Built
Axle/Gears: 3.73 POSI
Re: Metal in oil pan
can anyone tell me what this metal pieces I found it in a boil pan well changing a gasket. underneath th underneath the engine and when I had th and when I had the heads of everything looked good up top. It is magnetic
EDIT it kinda looks like a piece of inner valve spring.
Car: 1984 TA - 17k orig miles
Engine: 355
Axle/Gears: 3.44 Dana 44 performance rear
I would agree with the piece of inner valve spring given the thickness and shape of it and it looks smooth on both long edges - is the other end where the break was?
I think it might be this. I will find out today and if it is the spring I will get some rope out and fix it.
Fricken scary moment looking in the pan. I spent 2 hours turning the engine and looking at the bottom end carefully no damage to be found.
Engine: 4++,350 & 305 CIs
Yup, looks like a valvespring dampener to me also.
Yea I know I will inspect again tonight and look under the covers. There is also the off chance that it was something from the previous owner. I just cannot place it in my head from its size.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Well I mean there are oil drains in the heads, are there not? I figure it just broke and flew to a place where oil was flowing, and ended up in the pan.
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
Yes, I'm not recalling the size in a SBC at the moment but in most engines they are fairly large passages that readily accept screws and other smallish things and drain straight to the crankcase. That being why there is no return plumbing shown in that picture of the lubrication system.
Ok good news for me. I popped off the valve cover and found the broken dampener as well as two more pieces of it.
I could not find any other broken dampeners.
I sent an email to patriot and they are sending me a free replacement
I just wanted to mention that patriot had the replacement to me in 2 days free of charge with no issues.
Although they are called promaxx now.
